Join shape and dbms data: OGR?
Michael Schulz
mschulz at WEBGIS.DE
Mon Nov 15 10:03:49 EST 2004
Frank Warmerdam schrieb:
> Michael Schulz wrote:
>> Dear List,
>> i want to evaluate the possibility to integrate a layer in mapserver,
>> that takes the geometry data
>> from a shape file (polygons with a unique id) and the attribute data
>> from a MS-Access DB (this is
>> unfortunately a precondition). The attribute data should be joined
>> with the shape-file unique
>> polygon id and thus accessible for classification and labeling.
>> I looked through the OGR connection possibilities and now i am
>> wondering if this could be achieved
>> using an OGR virtual datasource, which has a SQLSrc defined that
>> performs the join?
> Michael,
> In theory you can do it via an OGR connection without even using the VRT
> stuff. The DATA statement in the map file can be a SELECT statement when
> you are using the OGR connection type. In theory if you connect to a
> shapefile
> you could have a select statement that also joins attribute information
> from
> an ODBC connection.
> First, I think you will need to have a .dbf associated with your
> shapefile that
> has at least your relation key. I don't think it is possible to use the
> FID
> (ie. the shapefile sequence number) in the OGR SQL statements.
> You might use something like:
> SELECT * from city
> LEFT JOIN 'ODBC:YourAccessDSN'.city_info ON city.id = city_info.id
> assuming your shapefile is called "city.shp" and has a column called id,
> and that your msaccess table is called city_info and also has a column
> called id to relate on.
> The 'ODBC:<YourAccessDSN>' portion of the above is a bit of OGR SQL special
> syntax allowing you to refer to a different datasource than the one you
> listed
> in your CONNECTION string. Assuming you have setup a system DSN called
> YourAccessDSN, and that there are no userid or password required it
> would look
> something like the above.
> I would add that connecting to ODBC datasources with alot of tables can be
> somewhat expensive. If there are alot of tables in your access
> database, you
> might want to list the one you want access to in the datasource name so OGR
> only has to collect the table definition for that one table.
> Lastly, OGR is going to end up doing a SELECT on the ODBC datasource for
> each
> shape it reads from the shapefile. Something like "selct * from city_info
> where id = <n>". So make sure you index your secondary table on relation
> key or performance will completely suck. As it is, this will not
> exactly be
> a high performance operation.
> Useful info:
> http://ogr.maptools.org/ogr_sql.html
> http://ogr.maptools.org/drv_odbc.html
> Good luck,
Hi Frank,
thanks for your answer. It is working perfectly now.
For the moment it is only one table i want to join to the geometry of the shp-file, so at first
sight performance is good, but i will play with the indexes a little.
For all who have to use a similar approach here's a mapfile snipplet:
LAYER
CONNECTIONTYPE OGR
CONNECTION "c:\mstest\data\fnpf.shp" # shapefile holding only geometry and PID in .dbf
DATA "SELECT * FROM fnpf LEFT JOIN 'ODBC:fnp'.fnp ON fnpf.PID=fnp.PID"
# join to systemDSN fnp (here msaccess-db "fnp.mdb" with table fnp) on attribute PID,
# now all fields of the db are also accessible for mapserver, e.g. "AZJAHR"
LABELITEM "AZJAHR"
END
Thanks, Michael
Michael Schulz in medias res
Dipl.-Geologe Gesellschaft für
Informationstechnologie mbH
In den Weihermatten 66
79108 Freiburg
0761 55695-95 (Fax 96)
mschulz at webgis.de www.webgis.de/www.zopecms.de
