Join shape and dbms data: OGR?
Bart van den Eijnden
bartvde at XS4ALL.NL
Tue Nov 16 15:36:03 EST 2004
Hi Emil,
the problem with the OGR shapefile connector is (or was) that it does not
use the spatial index (qix) files, so it isn't very fast ...
Question for Frank:
Or did this change as well with the current version :) ? I know you were
planning on doing this ...
Best regards,
Bart
On Tue, 16 Nov 2004 08:21:20 +0100, Emil Zegers
<EZS at SYNCERA-ITSOLUTIONS.NL> wrote:
> Hello Michael,
> I have a question for you about this approach: when using this kind of
> join were you able to classify data based on the joined attributes and
> display this in the map image?
> I'm asking this because with normal join operation it is not possible to
> create thematic maps based on the joined attributes.
> If classifcation works based on this approach the enhancement request I
> put in bugzilla (http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=674)
> can be closed.
> I would be very happy if classifying on joined attributes works this way
> (had no time to test this approach yet).
> Regards,
> Emil Zegers
> Hi Frank,
> thanks for your answer. It is working perfectly now.
> For the moment it is only one table i want to join to the geometry of
> the shp-file, so at first
> sight performance is good, but i will play with the indexes a little.
> For all who have to use a similar approach here's a mapfile snipplet:
> LAYER
> CONNECTIONTYPE OGR
> CONNECTION "c:\mstest\data\fnpf.shp" # shapefile holding only
> geometry and PID in .dbf
> DATA "SELECT * FROM fnpf LEFT JOIN 'ODBC:fnp'.fnp ON
> fnpf.PID=fnp.PID"
> # join to systemDSN fnp (here msaccess-db "fnp.mdb" with table
> fnp) on attribute PID,
> # now all fields of the db are also accessible for mapserver, e.g.
> "AZJAHR"
> LABELITEM "AZJAHR"
> END
> Thanks, Michael
Using Opera's revolutionary e-mail client: http://www.opera.com/m2/
