SLD filter with raster layers
Yewondwossen Assefa
assefa at DMSOLUTIONS.CA
Tue Nov 16 16:00:42 EST 2004
There is a bug open on that wich is basically an update of the existing
doc and the inegration of it in the mapserver documentation stream.
Bart van den Eijnden wrote:
> Hi Frank,
> okay so that's from the 4.2 days, I did not know that. I read it in the
> SLD docs on the Wiki.
> Btw, is there any new documentation for the SLD part of Mapserver coming
> with the 4.4 release, or is the following link still the most current
> version?
> http://www2.dmsolutions.ca/tmp/Mapserver_SLD.html
> Best regards,
> Bart
> On Tue, 16 Nov 2004 09:53:51 -0500, Frank Warmerdam <warmerdam at POBOX.COM>
>>> Hi Berend,
>>> is your raster 8 bit? AFAIK it does work but only with 8 bit rasters.
>> Bart,
>> Note, in MapServer 4.4 the raster classification support should work with
>> non-8bit layers as well with a few limitations. The SLD definitions are
>> just converted into class definitions internally I believe.
>> Berend Veldkamp wrote:
>> > Bart,
>> > Yes it's an 8 bit geotiff. Would it make any difference if I use
>> native
>> > tiff support instead of GDAL?
>> Well, hopefully it won't get any better to use the native support. If
>> it does
>> I would want to hear about it!
>> Best regards,
>> I set the clouds in motion - turn up | Frank Warmerdam,
>> warmerdam at pobox.com
>> light and sound - activate the windows | http://pobox.com/~warmerdam
>> and watch the world go round - Rush | Geospatial Programmer for Rent
> Using Opera's revolutionary e-mail client: http://www.opera.com/m2/
Assefa Yewondwossen
Software Analyst
Email: assefa at dmsolutions.ca
http://www.dmsolutions.ca/
Phone: (613) 565-5056 (ext 14)
Fax: (613) 565-0925
