Postgis nquery returns the same result multiple times
Paul Ramsey
pramsey at REFRACTIONS.NET
Wed Nov 17 12:37:50 EST 2004
James, if you make a bugzilla entry for this we will have a look at it,
but be forwarned, it might be a while before we have the discretionary
time to do this.
Paul
James Martin wrote:
> I'm trying to perform a nquery on a postgis layer and am recieving a weird
> result. If my DATA = "the_geom from place" the query works fine. However,
> when trying:
> (SELECT place.the_geom AS the_geom,
> place.gid AS gid,
> place.name AS name
> FROM place
> WHERE place.gid=9)
> AS foo USING UNIQUE place.gid
> USING SRID=-1"
> And then bound a point with &imgbox the query returns the correct record,
> but returns it 'N' times, where N is the number of rows in the table. The
> map itself shows only the one point specified in the WHERE clause. If I
> remove the WHERE clause so I can see the other points and bound two of them,
> the query returns the first record 2 * N times.
> If I do just a query with &imgxy it returns just the one result.
> Any help is greatly appreciated!
> -James
