jBox Java applet
Manjiri Andhare
mandhare at STATE.PA.US
Thu Nov 18 08:29:16 EST 2004
Hi!
I was looking for the functionality to draw a rectangle for zooming in on
the map. I found jBox by Steve Lime on
http://mapserver.gis.umn.edu/contributed.html
I have Windows 2000 and I'm running mapserver 4.2 on IIS.
I follwed the steps from jBox HOWTO 4.2 to test it with the workshop demo.
But when i try to run the workshop demo with "Basic application" option, in
the status bar of Browser(I'm using IE 6.0) I get the message as;
Loading Java Applet Failed..
And I'm not getting the reason behind this..
Here is the changed portion of itasca_basic.html file:
<html>
<head>
<title>MapServer - Itasca Application</title>
<script language="javascript">
function setbox_handler(name,minx,miny,maxx,maxy)
document.mapserv.imgbox.value = minx + " " + miny
+ " " + maxx + " " + maxy;
document.mapserv.imgxy.value = minx + " " + miny;
//additional code can go here prior to the form
submit, below
//for example, form validation code.
document.mapserv.submit();
function seterror_handler(message)
alert(message);
</script>
</head>
<body bgcolor="#ffffff">
<center><h1>MapServer - Itasca Application</h1></center>
<hr>
<form method="GET" action="cgi-bin/mapserv.exe" name="mapserv" >
<center>
<table border="0" cellspacing="0" cellpadding="4">
<tr>
<td valign="top" align="center">
<table width="390" border="0" cellspacing="0" cellpadding="4"
align="center" bgcolor="#666666">
<tr>
<td colspan="2">
<applet
codebase="java\jBox"
archive="jBoxPNG.jar,png.jar"
code="jBoxPNG.class"
width="600"
height="600"
name="jBox"
MAYSCRIPT>
<param name="image" value="http:\\[host][img]">
</applet>
</td>
</tr>
<tr><td bgcolor="#666666">
<img title="scalebar (mi)" alt="scalebar (mi)" src="[scalebar]">
</td></tr>
</table>
</td>
<td valign="top" bgcolor="#ffffff">
<table cellpadding="5" cellspacing="0" border="0" bgcolor="#ffffff">
<tr><td>
<center><input type="submit" value="Refresh/Query"></center>
<p>
<input type="radio" name="mode" value="browse" checked> <b>Browse
map</b><br>
<input type="radio" name="mode" value="query"> <b>Query
feature</b><br>
<input type="radio" name="mode" value="nquery"> <b>Query multiple
features</b>
<hr>
<p>
<b>Select Layers to Display: </b><br>
<select multiple name="layer" size=3>
<option value="airports" [airports_select]> Airports
<option value="cities" [cities_select]> Cities
<option value="lakespy2" [lakespy2_select]> Lakes & Rivers
<option value="dlgstln2" [dlgstln2_select]> Streams
<option value="roads" [roads_select]> Roads
<option value="twprgpy3" [twprgpy3_select]> Townships
<option value="drgs" [drgs_select]> USGS 1:250,000 Quads
</select>
<p>
Zoom In <input type=radio name=zoomdir value=1 [zoomdir_1_check]>
Pan <input type=radio name=zoomdir value=0 [zoomdir_0_check]>
Zoom Out <input type=radio name=zoomdir value=-1 [zoomdir_-1_check]>
<p>
Zoom Size <input type=text name=zoomsize size=4 value=[zoomsize]>
<p>
<font size=+1><b>Legend</b></font><br><hr>
<img src="[legend]"><hr>
<p>
<center>
<input name="ref" type="image" src="[ref]"
border="0"></center>
</td></tr></table>
</td></tr>
</table>
</center>
<input type="hidden" name="imgbox" value="-1 -1 -1 -1">
I have placed the jBox as:
c:\Inetpub\wwwroot\MapServer\java\jBox
And I have placed the jar files, class files and java source files from
lib,classes and src folders respectively under
If somebody could point out what i'm missing,it'll be great!!
Thank you,
Manjiri Andhare
GIS Coordinator
PA Fish & Boat Commission
U.S.A.
