OGR connection vs shp DATA
Frank Warmerdam
warmerdam at POBOX.COM
Thu Nov 18 10:08:32 EST 2004
Eduin Carrillo wrote:
> Can somebody explain me benefits of using OGR as shapefile datasource vs.
> reading shp files directly?
Eduin,
Advantages of using OGR for shapefile access:
o OGR is slower than built-in Shapefile support because of many extra
layers of abstraction and conversion.
o OGR is slower because it doesn't currently support use of spatial
indexes for shapefiles while the built-in mapserver shapefile support
does. (Note: I actually have support for mapserver style spatial indexes
half implemented in my local development tree, but no ETA).
o OGR supports "OGR SQL" in the DATA statement, though most effects you
might accomplish that way can be simulated at least as efficiently using
MapServer expressions and other mechanisms.
o You can use OGR style joins, including the ability to join to some
non-shapefile types of stuff as long as it is supported by OGR. I am
not sure how OGR joining compares to the built-in mapserver joins that
work for shapefiles.
Basically, except for rare circumstances you are better off using the
built-in shapefile support instead of accessing through OGR.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
