expression string
Roman Meier
mapserver at GISMAP.CH
Thu Nov 18 15:48:25 EST 2004
Hi list
I've got a problem using the same expression string multiple times. It seems
that a can use a specific expression only one single time within a map-File.
When I use it a second time mapserver (4.0.2 and 4.2.5) returns an empty
page. Is it possible to use the same expression multiple times?
I'm using the following expression:
CLASS
NAME "blabla"
EXPRESSION ('[SYSTEM]' eq 'Schmutz')
TEMPLATE "template/schacht.html"
Any ideas? Thanks in advance!
Roman
