PostGIS vs MyGis
Bart van den Eijnden
bartvde at XS4ALL.NL
Fri Nov 19 05:53:39 EST 2004
Hi Bjoern,
the MyGIS datastore for Mapserver stores geometry in WKB format (or WKT)
in a MySQL database field. It has its own Perl convertor to put the data
into MySQL by using a shapefile as input.
Mapserver has no support (as yet) for the MySQL spatial extensions which
were released in MySQL 4.1.
Best regards,
Bart
> Hi Bart,
>> are you referring to the MySQL spatial extensions which have
>> been released in MySQL 4.1, or are you talking about the
>> MyGIS connector in Mapserver, which is storing geometries as
>> WKB in MySQL?
> Can you explain the difference to me? Mustn't I use CONNECTIONTYPE mygis
> when I want to use the MySQL spatial extensions????
> If not, what _do_ I have to use??
> Maybe that could solve an actual problem here...
> Bye,
> Bjoern.
