problem with postGIS and WMS capabilities if wms_extent not
defined
Bart van den Eijnden
bartvde at XS4ALL.NL
Fri Nov 19 07:33:33 EST 2004
Hi list,
I have a PostGIS layer in my MAP file and I am using the 4.4 beta2 windows
binary from maptools.org. I am on Windows 2000 server.
If I don't define a WMS_EXTENT in the METADATA section of my LAYER, I get
a crash of the WMS capabilities (only 4 Kb of normally 5 Kb is sent). If I
do define the WMS_EXTENT everything works fine.
The last part of the capabilities received is:
<GetLegendGraphic>
<Format>image/png</Format>
<Format>image/gif</Format>
<Format>image/jpeg</Format>
<Format>image/wbmp</Format>
<Format>application/x-shockwave-flash</Format>
<Format>text/html</Format>
<Format>application/x-pdf</Format>
<Format>image/tiff</Format>
<DCPType>
<HTTP>
<Get><OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink"
xlink:href="http://myserver/cgi-bin/mapserv.exe?map=/ms4w/apps/general/map/top50postgis.map&"/></Get>
<Post><OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink"
Is this a known issue with 4.4 beta2?
Best regards,
Bart
