line with arrows
joerg pfeiffer
superbla3000 at GMX.NET
Fri Nov 19 09:23:28 EST 2004
thanks a lot! That's what I needed.
First i had some probems with webdings, but then I changed the symbol to:
SYMBOL
NAME "arrow"
TYPE TRUETYPE
FONT verdana
CHARACTER ">"
FILLED true
ANTIALIAS true
GAP -70
END
best regards
Joerg
fx gamoy wrote:
> Hello,
> you should use this
> SYMBOL
> NAME 'test'
> TYPE TRUETYPE
> FONT 'webdings'
> CHARACTER ""
> FILLED true
> ANTIALIAS true
> GAP -25 # the negatation tells MapServer to honor the vector direction
> when computing the angle
> END
> you need to get a webdings.ttf file in your fonts.txt
> exemple of layer
> LAYER
> NAME 'a line'
> TYPE LINE
> STATUS ON
> CLASS
> STYLE
> COLOR 0 0 0
> SYMBOL "circle"
> SIZE 1
> END
> STYLE
> SYMBOL 'test'
> COLOR 0 0 0
> SIZE 14
> END
> END
> FEATURE
> POINTS 10 10 50 100 100 300 300 300 10 490 END
> END
> END
> this works with mapserver 4.0 & up
> fx
> ----- Original Message -----
> From: "joerg pfeiffer" <superbla3000 at GMX.NET>
> To: <MAPSERVER-USERS at LISTS.UMN.EDU>
> Sent: Friday, November 19, 2004 1:06 PM
> Subject: [UMN_MAPSERVER-USERS] line with arrows
>>hello,
>>I would like to draw a line with an arrow in it.
>>The arrow should always point in the line direction, so if the line goes
>>up 30 degrees or so, the arrow does the same.
>>Joerg
