Trouble with Projection
Ed McNierney
ed at TOPOZONE.COM
Fri Nov 19 09:59:25 EST 2004
Jim -
Frank's making essentially the same suggestion I am, but I would recommend you use his solution instead. I had forgotten about that option and I always think it's safer to use defined constants rather than numeric values when you can - they're much less prone to typos!
- Ed
-----Original Message-----
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On Behalf Of Frank Warmerdam
Sent: Friday, November 19, 2004 9:52 AM
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: Re: [UMN_MAPSERVER-USERS] Trouble with Projection
Jim Shanton wrote:
> I’m trying to plot a property parcel shp file, and it keeps plotting
> in Pennsylvania instead of North Carolina.
> PROJECTION
> proj=lcc
> lat_0=33.75 #Latitude of False Origin
> lon_0=-79.0 #Longitude of Natural Origin (Central
> Meridian)
> lat_1=34.33333333333334 #Latitude of First Standard Parallel
> lat_2=36.16666666666666
> x_0=2000000.002616666 # False Easting
> y_0=0.0 # False Northing
> ellps=GRS80 # SPHEROID
> a=6378137.0 # from SPHEROID
> ["GRS_1980",6378137,298.257222101]],
> rf=298.257222101 #from SPHEROID
> datum=NAD83
> END
> UNIT["Foot_US",0.3048006096012192]]
Jim,
I think your main problem is the linear units. The default units in
PROJ.4 is meters, but you need US feet. Try adding a "units=us-ft"
in your PROJECTION declaration for the layer. There is also some slight chance you will need to alter the x_0 parameter by multiplying (or
dividing) by the meter/feet conversion ratio, but I doubt that will be needed.
Good luck,
and watch the world go round - Rush | Geospatial Programmer for Rent
