my app can not find template
Ethan Alpert
ealpert at DIGITALGLOBE.COM
Fri Nov 19 11:29:09 EST 2004
In this case you don't appear to need a TEMPLATE. I'm not sure but I
think you can put the string "dummy" into your template line. The
TEMPLATE option is really for calls where mode=browse and you only pass
the mapfile name to the mapserv executable.
-e
-----Original Message-----
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On
Behalf Of Joseph Norris
Sent: Thursday, November 18, 2004 5:44 PM
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: Re: [UMN_MAPSERVER-USERS] my app can not find template
Ok - here is what I have.
I have a perl cgi that builds my primary page, builds the map file and
uses the perl api to build the map image, then displays the page. In
the initial page I have all of the hidden fields that will direct that
are to be read by the mapserver to allow me to zoom into different
polygons on my California zip map ( each polygon representing a zip ).
The cgi produces the following html:
<html>
<head>
<title>MapServer - CS CGI Application</title>
</head>
<body bgcolor="#ffffff">
<!-- map_template.html -->
<center><h1>MapServer - CS CGI Application</h1></center>
<hr>
<form method="GET" action="/cgi-bin/teacher/makmap.cgi"
name="mapserv_select">
<center>
<table border="0" cellspacing="0" cellpadding="4">
<tr>
<td>
Teacher Type: <SELECT NAME="type">
<OPTION VALUE="type1" >First Grade Teacher</option>
<OPTION VALUE="type2" >Second Grade Teacher</option>
<OPTION VALUE="type3" >Third Grade Teacher</option>
<OPTION VALUE="none" SELECTED></option>
</SELECT>
<input type="submit" value="Submit">
<input type="hidden" name="action" value="submit">
</form>
<form method="GET" action="/cgi-bin/mapserv" name="mapserv"> <input
type="hidden" name="zoomsize" value=2> <input type="hidden" name="map"
value="/usr/local/apache/htdocs/mco.communityservers.com/htdocs/tmp/file
tRBR
Uk.map">
<input type="hidden" name="map_web_imagepath"
value="/usr/local/apache/htdocs/mco.communityservers.com/htdocs/maps/tmp
/fil
eWHBLVG.gif">
<input type="hidden" name="map_web_template"
value="/usr/local/apache/htdocs/mco.communityservers.com/htdocs/maps/tea
cher
/templates/map_template.html">
<input type="hidden" name="map_web_imageurl" value="/maps/tmp"> <input
type="hidden" name="root" value="/maps/teacher";
></td>
</tr>
<tr>
<td valign="top" align="center">
<table width="390" border="0" cellspacing="0" cellpadding="4"
align="center" bgcolor="#666666">
<tr>
<td align="center"><input type="image" name="img"
src="/maps/tmp/fileWHBLVG.gif" width="600" height="600" border="0"
alt="this is the map">
</td>
</tr>
</table>
</td>
</tr>
</table>
</body>
</html>
The html consists of two forms one for selection of the criteria which
rebuilds the map just fine. The second for looking at the polygons. My
map file that is produced appears as follows on the initial display of
the map:
MAP
NAME CalMap
STATUS ON
EXTENT 5890870.385 -192053.200 8943310.847 3226086.749
IMAGETYPE GIF
SIZE 600 600
SHAPEPATH
"/usr/local/apache/htdocs/mco.communityservers.com/htdocs/maps/teacher/t
data
IMAGECOLOR 255 255 255
SYMBOL
NAME 'circle'
TYPE ELLIPSE
POINTS 1 1 END
FILLED TRUE
END
LAYER
NAME "cal_zp_st"
TYPE POLYGON
DATA "cal_zp_st"
STATUS DEFAULT
CLASSITEM "ZCTA"
CLASS
EXPRESSION /./
OUTLINECOLOR 204 204 204
END
END
END # end map from header
And after selection of specific criteria:
MAP
NAME CalMap
STATUS ON
IMAGETYPE GIF
SIZE 600 600
SHAPEPATH
data
SYMBOL
NAME 'circle'
TYPE ELLIPSE
POINTS 1 1 END
FILLED TRUE
END
LAYER
NAME "cal_zp_st"
TYPE POLYGON
DATA "cal_zp_st"
STATUS DEFAULT
CLASSITEM "ZCTA"
CLASS
EXPRESSION
/94087|90408|94107|95118|94530|94596|90037|91016|92024|94954|93901|92503
STYLE
SYMBOL 'circle'
SIZE 2
COLOR 255 102 102
END
END
CLASS
EXPRESSION /./
END
END
My error condition comes about when I try to click on one of the
polygons in the map.
#Joseph Norris (Perl - what else is there?/Linux/CGI/Mysql) print @c=map
chr
$_+100,(6,17,15,16,-68,-3,10,11,16,4,1,14,-68,12,1,14,8,-68,4,-3,-1,7,1,
14,-
68,-26,11,15,1,12,4,-68,-22,11,14,14,5,15,-90);
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at lists.umn.edu]On
Behalf Of Ryan, Adam
Sent: Thursday, November 18, 2004 3:02 PM
To: MAPSERVER-USERS at lists.umn.edu
> From: Joseph Norris [mailto:sirronj at PACBELL.NET]
> Sent: Thursday, November 18, 2004 2:25 PM
> Subject: [UMN_MAPSERVER-USERS] my app can not find template
> Hello,
> I am getting this message:
> mapserv(): Web application error. No template provided
> I have a hidden field <input type="hidden" name="map_web_template"
> value=" this I am not sure of ">
> Should my hidden field be the root relative or absolute path?
> No matter what I try my app is not finding my template.
> Thanks ahead of time.
> @c=map chr
> -3,-1,7,1,14,- 68,-26,11,15,1,12,4,-68,-22,11,14,14,5,15,-90);
Joseph,
Just want to make sure your setting the value to a file, not just a
path, and not a url. Give us the examples that you've used.
Adam
