Perl MapScript - newbie blues
Eric Bridger
eric at GOMOOS.ORG
Sat Nov 20 16:53:58 EST 2004
Have you discovered the mapserver wiki?
There is a section on PerlMapscript and a page of examples:
http://mapserver.gis.umn.edu/cgi-bin/wiki.pl?PerlMapScriptExamples35
At the very bottom of that page you'll find a Mapscript 4.2 example which should help you get started drawing points.
I'd be happy to share additional code, I have several large Perl Mapscript applications. (Mostly 3.6).
Eric
At 08:03 PM 11/20/2004 +0100, Aaron Craig wrote:
>-----BEGIN PGP SIGNED MESSAGE-----
>Hash: SHA1
>Hi all.
>Can anyone point me to some working examples of using Perl to
>manipulate the map image? Specifically, I need to be able to draw
>lines, dots and other features on an existing map. Being able to
>dynamically create and display entire layers would also be great.
>I've looked high and low for examples, but find none. Also, it seems
>that the documentation for MapScript is not completely updated (no
>examples come to mind and I'm not on the computer that I am developing
>this project on), so I'm having some trouble getting things working.
>I can also post a code snippet of what I'm trying to do, but as this
>must be simply newbie madness, I'm assuming that if I can find some
>working examples of Perl MapScript, I'll be able to figure things out
>for myself.
>Thanks in advance!
>Aaron Craig
>mercutio at pobox.com
>Get Firefox!
>http://www.spreadfirefox.com/?q=affiliates&id=0&t=1
>Asses are made to bear, and so are you. --The Taming of the Shrew, II:1
>-----BEGIN PGP SIGNATURE-----
>Version: GnuPG v1.2.3-nr1 (Windows 2000)
>Comment: Using GnuPG with Thunderbird - http://enigmail.mozdev.org
>iD8DBQFBn5UAoyEQRcU83p4RAnmlAJoDMaNJz+31tcimMfaB74L2LviXoACdG67J
>48du8ARdlUtqq0p24IanLK8=
>=Nv2Y
>-----END PGP SIGNATURE-----
