WFS Metadata versus connection string (envdat WFS)
Kralidis,Tom [Burlington]
Tom.Kralidis at EC.GC.CA
Mon Nov 22 13:18:24 EST 2004
> Tyler Mitchell wrote:
> > I'm working with this WFS data:
> http://map.ns.ec.gc.ca/envdat/map.aspx?service=WFS&version=1.0.0&reque
> > st=GetCapabilities
> > It works, but I'm a bit confused when using the data in my
> map file.
> > If I put the parameters manually into the connection string/URL, it
> > works. But if I put parameters like wfs_version,
> wfs_request into the
> > metadata section for the layer (and remove them from the URL) it
> > doesn't seem to work anymore.
> Are you using 4.2 or 4.4?
> If you are using 4.4, then wfs_* metadata should be supported
> (and the old method of passing everything in the CONNECTION
> string deprecated), but unfortunately the WFS Client HOWTO
> still hasn't been updated to reflect that. You may find some
> useful hints in bug 417:
> http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=417
Actually, I just tested this again with 4.4.0-beta2, and get the same
issues Tyler has (parameters embedded in CONNECTION work, parameters as
METADATA/wfs_* with no parameters in CONNECTION does not).
When I try this, .gml files are written to my temp directory. Upon
checking these w.r.t. this issue, they all come back as OGC service
exceptions, like:
"VERSION keyword missing"
..and so on.
..Tom
