WFS Metadata versus connection string (envdat WFS)
Kralidis,Tom [Burlington]
Tom.Kralidis at EC.GC.CA
Mon Nov 22 15:40:15 EST 2004
Assefa,
This might the case. The server is running 4.2.0, client 4.4.0-beta2.
I won't be pushing our people to update until 4.4.0 proper on the server
side.
..Tom
> -----Original Message-----
> From: Yewondwossen Assefa [mailto:assefa at dmsolutions.ca]
> Sent: Monday, 22 November, 2004 15:38
> To: Kralidis,Tom [Burlington]
> Cc: MAPSERVER-USERS at LISTS.UMN.EDU
> Subject: Re: [UMN_MAPSERVER-USERS] WFS Metadata versus
> Tom,
> Ist it possible that the wfs *server* is running an older
> version of
> Mapserver (when the xml post requests were not yet supported)
> and that
> the client is runnign using a more recent version ?
> Later,
> Kralidis,Tom [Burlington] wrote:
> >>Tyler Mitchell wrote:
> >>>I'm working with this WFS data:
> >>http://map.ns.ec.gc.ca/envdat/map.aspx?service=WFS&version=1
> .0.0&reque
> >>>st=GetCapabilities
> >>>It works, but I'm a bit confused when using the data in my
> >>map file.
> >>>If I put the parameters manually into the connection string/URL, it
> >>>works. But if I put parameters like wfs_version,
> >>wfs_request into the
> >>>metadata section for the layer (and remove them from the URL) it
> >>>doesn't seem to work anymore.
> >>Are you using 4.2 or 4.4?
> >>If you are using 4.4, then wfs_* metadata should be supported
> >>(and the old method of passing everything in the CONNECTION
> >>string deprecated), but unfortunately the WFS Client HOWTO
> >>still hasn't been updated to reflect that. You may find some
> >>useful hints in bug 417:
> >>http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=417
> > Actually, I just tested this again with 4.4.0-beta2, and
> get the same
> > issues Tyler has (parameters embedded in CONNECTION work,
> parameters
> > as
> > METADATA/wfs_* with no parameters in CONNECTION does not).
> > When I try this, .gml files are written to my temp directory. Upon
> > checking these w.r.t. this issue, they all come back as OGC service
> > exceptions, like:
> > "VERSION keyword missing"
> > ..and so on.
> > ..Tom
> Assefa Yewondwossen
> Software Analyst
> Email: assefa at dmsolutions.ca
> http://www.dmsolutions.ca/
> Phone: (613) 565-5056 (ext 14)
> Fax: (613) 565-0925
