WFS Metadata versus connection string (envdat WFS)
Tyler Mitchell
tylermitchell at SHAW.CA
Tue Nov 23 00:42:41 EST 2004
Ooops, just getting caught up on email and found this solution.
Thanks for this Assefa-now I understand what you were talking about in the
bug.
Things are resolved on the WFS front me now.
Tyler
On November 22, 2004 01:16 pm, Yewondwossen Assefa wrote:
> Tom,
> You still can acheive what you want if you set on your layer
> "wfs_request_method" "GET" forcing mapserver to send a get request. I
> tried it your data and It seems to work. There was a small problem tough
> were the connection element in your demo map file for your layer was
> missing a trailing "?". There was no check done on this (Bug 1082 has
> been enered for this).
> Later,
> Kralidis,Tom [Burlington] wrote:
> > Assefa,
> > This might the case. The server is running 4.2.0, client 4.4.0-beta2.
> > I won't be pushing our people to update until 4.4.0 proper on the server
> > side.
> > ..Tom
> >>-----Original Message-----
> >>From: Yewondwossen Assefa [mailto:assefa at dmsolutions.ca]
> >>Sent: Monday, 22 November, 2004 15:38
> >>To: Kralidis,Tom [Burlington]
> >>Cc: MAPSERVER-USERS at LISTS.UMN.EDU
> >>Subject: Re: [UMN_MAPSERVER-USERS] WFS Metadata versus
> >>Tom,
> >> Ist it possible that the wfs *server* is running an older
> >>version of
> >>Mapserver (when the xml post requests were not yet supported)
> >>and that
> >>the client is runnign using a more recent version ?
> >>Later,
> >>>>Tyler Mitchell wrote:
> >>>>>I'm working with this WFS data:
> >>>>http://map.ns.ec.gc.ca/envdat/map.aspx?service=WFS&version=1
> >>.0.0&reque
> >>>>>st=GetCapabilities
> >>>>>It works, but I'm a bit confused when using the data in my
> >>>>map file.
> >>>>>If I put the parameters manually into the connection string/URL, it
> >>>>>works. But if I put parameters like wfs_version,
> >>>>wfs_request into the
> >>>>>metadata section for the layer (and remove them from the URL) it
> >>>>>doesn't seem to work anymore.
> >>>>Are you using 4.2 or 4.4?
> >>>>If you are using 4.4, then wfs_* metadata should be supported
> >>>>(and the old method of passing everything in the CONNECTION
> >>>>string deprecated), but unfortunately the WFS Client HOWTO
> >>>>still hasn't been updated to reflect that. You may find some
> >>>>useful hints in bug 417:
> >>>>http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=417
> >>>Actually, I just tested this again with 4.4.0-beta2, and
> >>get the same
> >>>issues Tyler has (parameters embedded in CONNECTION work,
> >>parameters
> >>>as
> >>>METADATA/wfs_* with no parameters in CONNECTION does not).
> >>>When I try this, .gml files are written to my temp directory. Upon
> >>>checking these w.r.t. this issue, they all come back as OGC service
> >>>exceptions, like:
> >>>"VERSION keyword missing"
> >>>..and so on.
> >>>..Tom
> >>Assefa Yewondwossen
> >>Software Analyst
> >>Email: assefa at dmsolutions.ca
> >>http://www.dmsolutions.ca/
> >>Phone: (613) 565-5056 (ext 14)
> >>Fax: (613) 565-0925
> Assefa Yewondwossen
> Software Analyst
> Fax: (613) 565-0925
