problem with postGIS and WMS capabilities if wms_extent not
defined
Bart van den Eijnden
bartvde at XS4ALL.NL
Tue Nov 23 11:36:31 EST 2004
Hi list,
All below-mentioned problems are solved in 4.4 beta3, good work :)
Thanks.
Best regards,
Bart
On Fri, 19 Nov 2004 22:20:35 +0100, Bart van den Eijnden
<bartvde at xs4all.nl> wrote:
> Hi Daniel,
> yes, both 4.2 and 4.3 binaries work.
> Also GetMap requests work with a 4.3 or 4.2 binary, but the 4.4 beta2
> gives an internal server error.
> [Fri Nov 19 22:28:34 2004] [error] [client 192.168.3.4] Premature end of
> script headers: mapserv.exe
> So there seems to be something wrong with the PostGIS support in that
> one whenever it needs to go to the database for information. Anybody
> else experiencing this, or is it my specific setup?
> When will a 4.4 beta3 binary be released on maptools? As we never
> compile with PostGIS support unfortunately .... :(
> Best regards,
> Bart
> On Fri, 19 Nov 2004 16:10:23 -0500, Daniel Morissette
> <dmorissette at DMSOLUTIONS.CA> wrote:
>> Bart van den Eijnden wrote:
>>> Hi list,
>>> I have a PostGIS layer in my MAP file and I am using the 4.4 beta2
>>> windows
>>> binary from maptools.org. I am on Windows 2000 server.
>>> If I don't define a WMS_EXTENT in the METADATA section of my LAYER, I
>>> get
>>> a crash of the WMS capabilities (only 4 Kb of normally 5 Kb is sent).
>>> If I
>>> do define the WMS_EXTENT everything works fine.
>> Did this use to work with 4.2? Some work was dont in this area after
>> beta2, but I'm not aware of this issue. Perhaps you could also try with
>> the latest source from CVS if you can.
>> Daniel Morissette dmorissette at dmsolutions.ca
>> DM Solutions Group http://www.dmsolutions.ca/
Using Opera's revolutionary e-mail client: http://www.opera.com/m2/
