ms4w-installation: win98se-shutdown problem
Jeff McKenna
jmckenna at DMSOLUTIONS.CA
Tue Nov 23 12:45:58 EST 2004
Hello Joerg,
(note that the proper email list for MS4W questions can be found at
http://lists.maptools.org/mailman/listinfo/ms4w-users)
I dug up an old win98 laptop and did some testing with ms4w v1.0. I
also ran into problems stopping the service. I then did some digging
and from what I've read Apache's use as a 'service' is extremely
experimental in Windows 95/98
(http://www.phpfreaks.com/apache_manual/page/win_service.html#win95svc).
I therefore have no easy solution for you. To get around this I would
make a shortcut to apache.exe on my desktop and manually run it each
time...sorry I don't have an easier solution. Maybe some other win98
user can help us.
jeff
wenke wrote:
> Hi,
> when I want to close win98se, I always get the error, that
> apache an php is still running.
> I think, I installed it as service. But now I (have to) put it out of
> the autostart-system-configuration.
> Anybody knows, what I have to change in any config-file, so that
> win is working normaly again??
> Thanks for help,
> joerg
> start
> C:\ms4w\Apache\bin\apache.exe -n ApacheWebServer -k runservice (default)
> stop
> C:\ms4w\Apache\bin\apache.exe -k shutdown (default)
> monitor
> C:\ms4w\Apache\bin\ApacheMonitor.exe (default)
> ms4w Revision 1.02 |2004/07/21
> * Apache 2.0.50
> * PHP 4.3.7
Jeff McKenna
GIS Specialist
DM Solutions Group Inc.
http://www.dmsolutions.ca
