[UMN_MAPSERVER-USERS] problem after switching to linux
Skweda O'Bomsawin
sobomsawin at KASSINI.COM
Wed Nov 24 09:04:27 EST 2004
Your Apache user must have access to the directories and files. Take a look
at the permissions of files and folders where your mapfile and your php
files are stored with the command ls -l. Just as a test, chmod -R 777 * the
directory where your files are and try again your apps. Most of the time in
Linux, the problem is too much security, a kind of problem you never deal
with in Win (make your own conclusion...).
Regards,
Skweda O'Bomsawin
-----Message d'origine-----
De : UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] De la
part de joerg pfeiffer
Envoyé : 23 novembre 2004 16:00
À : MAPSERVER-USERS at LISTS.UMN.EDU
Objet : [UMN_MAPSERVER-USERS] problem after switching to linux
hello,
I built my map with mapscript on windows. Now, after installing it on
linux, I get this error:
Warning: [MapServer Error]: msProcessProjection(): unknown projection id
in /home/JP/public_html/worldmap/include/mapclassesNeu3.php on line 58
Warning: Failed to open map file
/home/JP/public_html/worldmap/mapfiles/worldmap4.map in
so, this error comes, when I process my .phtml mapscript file. If I call
the worldmap4.map file direct with mapserv?map=....worldmap4.map, there
is no problem. So it seem not to be the mapfile.
And I double checked the path to worldmap4.map file, tried it relative
and absolute, seems to be correct...
regards
Joerg
Incoming mail is certified Virus Free.
Checked by AVG anti-virus system (http://www.grisoft.com).
Version: 6.0.784 / Virus Database: 530 - Release Date: 2004-10-27
Outgoing mail is certified Virus Free.
