msRASTERLayerOpen(): General error message. Attempt to open a
RASTER layer, but this is only supported after a raster query
Bart van den Eijnden
bartvde at XS4ALL.NL
Thu Nov 25 10:30:46 EST 2004
Hi Assefa,
Gemeentes is a polygon shapefile layer on the WMS server. But the
Chameleon querybuilder works on the Gemeentes layer through a
CONNECTIONTYPE WMS type of layer (so a raster layer ...).
This layer definition is generated by the Chameleon querybuilder (so it
does apply an SLD), and includes an attribute selection together with a
spatial (bbox) selection.
Best regards,
Bart
> I suspect it is a similar/related bug filed in bug 1087. I suspect that
> It is trying to apply an SLD with a spatial filter to a raster layer on
> the server (Is Gemeentes layer on the server side set as a raster layer
> ?). I need to add a check on the layer type before doing a query. I have
> corrected this locally but could you confirm on the layer type of
> Gemeentes.
> Later,
> Bart van den Eijnden wrote:
>> Hi list,
>> if I use a wfs_filter in my METADATA section for a WMS layer in
>> php_mapscript_44 I get the following error message, and the map comes
>> back
>> fully red (the color depends on the color defined in my only class). If
>> I
>> use php_mapscript_42 the right selection comes back (INWONERS < 35000),
>> but php_mapscript_42 probably ignored the wfs_filter I guess?
>> If I comment out the wfs_filter I get back my selection in red.
>> What could be the problem? Is it a bug, or am I doing something wrong?
>> LAYER
>> CONNECTION
>> "http://myserver/cgi-bin/44beta3/mapserv.exe?map=/mymap.map&"
>> CONNECTIONTYPE WMS
>> DUMP TRUE
>> METADATA
>> "wms_srs" "EPSG:28992 EPSG:4326"
>> "wfs_filter" "<BBOX><PropertyName>Name</PropertyName><gml:Box
>> srsName=''><gml:coordinates>196744.44444448536,531411.1111111111
>> 276400.000000136,595433.3333333334</gml:coordinates></gml:Box></BBOX>"
>> "wms_name" "Gemeentes"
>> "wms_format" "image/png"
>> "wms_sld_body" "auto"
>> "wms_server_version" "1.1.0"
>> "wms_style" ""
>> "wms_title" "Gemeentes"
>> END
>> NAME "ExpressionBuilderAnnotation"
>> PROJECTION
>> "init=epsg:28992"
>> END
>> SIZEUNITS PIXELS
>> STATUS ON
>> TEMPLATE "blank.html"
>> TOLERANCE 0
>> TOLERANCEUNITS PIXELS
>> TYPE POLYGON
>> UNITS METERS
>> CLASS
>> EXPRESSION ( ([INWONERS] < 35000) )
>> METADATA
>> END
>> STYLE
>> COLOR 255 0 0
>> MAXSIZE 500
>> MINSIZE 1
>> SYMBOL 0
>> END
>> END
>> END
>> Thanks in advance.
>> Best regards,
>> Bart
> Assefa Yewondwossen
> Software Analyst
> Email: assefa at dmsolutions.ca
> http://www.dmsolutions.ca/
> Phone: (613) 565-5056 (ext 14)
> Fax: (613) 565-0925
