msRASTERLayerOpen(): General error message. Attempt to open a
RASTER layer, but this is only supported after a raster query
Bart van den Eijnden
bartvde at XS4ALL.NL
Fri Nov 26 04:47:46 EST 2004
Hi Assefa,
I have created bug 1092 about this issue, which inludes a test script, map
file and the output from shp2img which differs largely from the output
from php_mapscript_44 beta3.
http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=1092
Thanks in advance for looking into this.
Best regards,
Bart
Bart,
I have corrected bug 1087.
As for your bug, I could not really reproduce it with the same setting
using local test data. I am using php_mapscript and the mapserver cgi
to draw a layer setup as yours (WMS client to a polygon layer with
wms_sld_auto and wfs_filter set). I though that your layer on the server
side was set as RASTER, that's why it was related to bug1087. If it is
set as a Polygon, I really do not understand what the problem is. What I
have tried is :
- php_mapscript : open your wms client map and draw that layer
- mapserv.cgi : mode=map
Is it problem happening inside chameleon or you can reprodice it with
simple php scr4ipt or using mapserver cgi ? If that is the case would
you provide me with your cleint and server map/data files ?
Later,
