simple mapserver instrucctions don't work!!
Jose Luis Gonzalez
joseluismapserver at YAHOO.ES
Mon Nov 29 06:26:38 EST 2004
This is my code:
First of all I have this file:
package javamaps;
public class MapserverLibLoad{
public static void loadLibrary() throws UnsatisfiedLinkError{
System.loadLibrary("mapscript");
Then this is the principal program, as you see it is a servlet:
import javamaps.*;
import edu.umn.gis.mapscript.*;
import javax.ejb.*;
import javax.xml.parsers.*;
import javax.xml.transform.*;
import javax.xml.transform.dom.*;
import org.w3c.dom.*;
import java.sql.*;
import javax.sql.*;
import javax.naming.*;
import javax.servlet.*;
import javax.servlet.http.*;
import java.io.*;
public class test2 extends HttpServlet{
InitialContext initialContext=null;
static{
try{
MapserverLibLoad.loadLibrary();
}catch(UnsatisfiedLinkError e){
e.printStackTrace();
System.out.println("CONTINUE");
private Connection createDatabaseConnection()throws EJBException{
DataSource dataSource;
Connection connection;
PreparedStatement stmt;
try{
dataSource = (DataSource) initialContext.lookup("jdbc/lbs");
connection= dataSource.getConnection();
//System.out.println(" DATABSE:::::"+connection.getMetaData().getUserName());
return connection;
}catch (SQLException e){
throw (new EJBException(e));
}catch (NamingException e){
public void init (ServletConfig cfg){
try{
System.out.println("Try to init servlet");
System.out.flush();
initialContext= new InitialContext();
}catch(Exception e){
}//fin init
public void service (HttpServletRequest req, HttpServletResponse res){
Connection conexion=null;
String imei=null;
PrintWriter out=null;
Statement orden=null;
ResultSet rs=null;
String SQL=null;
try{ itemObj item = new itemObj();
System.out.println(" BIG NAME :>>"+item.getName()+"<<");
conexion=this.createDatabaseConnection();
imei=req.getParameter("IMEI");
out=res.getWriter();
SQL="SELECT * FROM Client WHERE Name=";
SQL=SQL+"'"+imei+"'";
orden=conexion.createStatement();
rs=orden.executeQuery(SQL);
res.setContentType("text/html");
out.println("</Body></HTML>");
out.println("<TABLE border=1>");
rs.next();//I move to the first row
out.println("<TR><TD COLSPAN=3>");
out.println("</TD></TR>");
out.println("<TR><TD>"+rs.getString("Name"));
out.println("</TD><TD>"+rs.getString("Mobile"));
out.println("</TD><TD>"+rs.getString("Telephone_Number"));
while (rs.next()){
out.println("</TABLE>");
}//fin try
catch (Exception e){
System.out.println(e);
}catch (Throwable e){
System.out.println("WRONGG POINT");
}finally{
try{
out.close();
rs.close();
conexion.close();
orden.close();
}//fin service
It seems as like he can't reach the mapserver librarys and I don't know why.It gives me this error:
java.lang.UnsatisfiedLinkError: new_itemObj
Can someone help me?
Know what I'm doing wrong?
Thank you
Jose Luis
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20041129/33343db6/attachment.html
