Question on queryByAttributes - multiple fields
Cord Thomas
cord at LUPINEX.COM
Mon Nov 29 18:55:03 EST 2004
Hello all
Using MapServer 4.4x and Perl Mapscript on Linux against a PostGIS
database, i am having difficulty with the queryByAttributes method on a
polygon layer.
I include my MAP snippet below, but basically, my code is this:
my $res = $mapLayer->queryByAttributes($map, $qryFlds,
$qryVals, $mapscript::MS_MULTIPLE);
where $qryFlds = "stateid,name"
and $qryVals = "(stateid='ME' and name='Knox')"
Is this the valid way to specify multiple fields - how can i get mapserver
to dump the full query string to the log file? i have a log file setup,
and if i screw up the query string, it throws an error, but these criteria
are right and mapserver reports this:
- msQueryByAttributes(): Search returned no results. No matching record(s)
found.
thanks in advance
.MAP snippet:
LAYER
NAME "counties"
STATUS OFF
TYPE POLYGON
DATA "wkb_geometry from county"
CONNECTION "user=tiger password=[somepassword] dbname=tiger
host=localhost port=543
2"
CONNECTIONTYPE POSTGIS
PROJECTION
"proj=latlong"
"datum=NAD83"
END
UNITS DD
CLASS
COLOR 74 135 33
OUTLINECOLOR 28 55 11
TEMPLATE /var/www/cellsign/map/states_sm.html
END
END
MAP snippet
