Question on queryByAttributes - multiple fields
Eduin Carrillo
yecarrillo at YAHOO.COM
Mon Nov 29 19:48:19 EST 2004
--- Cord Thomas <cord at LUPINEX.COM> escribió:
> Hello all
> Using MapServer 4.4x and Perl Mapscript on Linux against a PostGIS
> database, i am having difficulty with the queryByAttributes method on a
> polygon layer.
> I include my MAP snippet below, but basically, my code is this:
> my $res = $mapLayer->queryByAttributes($map, $qryFlds,
> $qryVals, $mapscript::MS_MULTIPLE);
> where $qryFlds = "stateid,name"
> and $qryVals = "(stateid='ME' and name='Knox')"
> Is this the valid way to specify multiple fields - how can i get mapserver
> to dump the full query string to the log file? i have a log file setup,
> and if i screw up the query string, it throws an error, but these criteria
> are right and mapserver reports this:
> - msQueryByAttributes(): Search returned no results. No matching record(s)
> found.
> thanks in advance
> .MAP snippet:
> LAYER
> NAME "counties"
> STATUS OFF
> TYPE POLYGON
> DATA "wkb_geometry from county"
> CONNECTION "user=tiger password=[somepassword] dbname=tiger
> host=localhost port=543
> 2"
> CONNECTIONTYPE POSTGIS
> PROJECTION
> "proj=latlong"
> "datum=NAD83"
> END
> UNITS DD
> CLASS
> COLOR 74 135 33
> OUTLINECOLOR 28 55 11
> TEMPLATE /var/www/cellsign/map/states_sm.html
> END
> END
It's really bad MS do not support native query in more than one field. This
behavior has not ever so. I developed at 2003 a like ArcView "Query Bulder"
based on Php and a complex javascript code using oMap->queryByAttribute()
function, but at version 3.7, MS no longer supports query multiple fields, so
my
querybuilder were lost.
Eduin Yesid Carrillo Vega
yecarrillo at yahoo.com
COLOMBIA
_________________________________________________________
Do You Yahoo!?
Información de Estados Unidos y América Latina, en Yahoo! Noticias.
Visítanos en http://noticias.espanol.yahoo.com
