jbox area
Richard Greenwood
richard.greenwood at GMAIL.COM
Tue Nov 30 09:27:55 EST 2004
On Mon, 29 Nov 2004 10:42:49 -0500, Arnold, Micheal B.
<micheal.arnold at nscorp.com> wrote:
> For some reason, the area that I am getting back for polygons using jbox
> seems to be off. The segment length and total length seem to be fine, but
> the area is off by a factor of about 5. Does anybody have any ideas or
> suggestions? Below are the measure_handler functions I am using.
> Thanks for the help!
> Mike Arnold
> function measure_handler(name, s, t, n, a)
> // c = 1 / 72dpi / 12inches_per_foot *
> 1.0003state_plane_scale_factor
> var c = 0.0011577546296296; // constant
> var f = [scale] * c; // scale factor
> if ((s>0) || (t>0))
> if (n < 3)
> defaultStatus = "This
> segment = " + distFormat(s*f) + ", Total = " + distFormat(t*f) + ", Number
> of vertices = " + n ;
> else
> of vertices = " + n + ", Area = " + distFormat(a*f) ;
> function roundFeet(x)
> var fpp = ([maxx] - [minx]) / [mapwidth]; // resolution
> (feet per pixel)
> if (fpp < 4) return (Math.round(x));
> if (fpp < 8) return (Math.round(x/5)*5);
> if (fpp < 17) return (Math.round(x/10)*10);
> if (fpp < 40) return (Math.round(x/25)*25);
> if (fpp < 80) return (Math.round(x/50)*50);
> return (Math.round(x/100)*100);
> function distFormat(x)
> var d;
> if (x > 7920) return ((Math.round(x/5280*10)/10) + " miles");
> d = roundFeet(x);
> if (d > 2640)
> return (d + " ft (" + (Math.round(x/5280*10)/10) + ")mile");
> return (d + " ft");
jBox returns an area in screen pixels. You must convert it to sq feet,
sq meters, sq miles, or whatever you like. I wrote the above functions
to convert to sq feet and/or acres for a state plane coordinate system
in US Survey Feet. You need to modify them for your coordinate system,
resloution setting (if not 72), and desired output units.
Regards,
Richard Greenwood
richard.greenwood at gmail.com
www.greenwoodmap.com
