gdal above 1.2.3 not building
Frank Warmerdam
fwarmerdam at GMAIL.COM
Tue Nov 30 13:38:24 EST 2004
On Tue, 30 Nov 2004 19:36:42 +0100, Benjamin Thelen <bt at ccgis.de> wrote:
> Hi list, hello Frank,
> I have a SuSE 9.0 with gcc-3.3.1 running and try to install
> gdal-1.2.5. I receive the following error at the end of ./configure. I
> suppose, that this is the reason why "make" stops. The same ist true
> for gdal-1.2.4.
> configure: creating ./config.status
> config.status: creating GDALmake.opt
> sed: file ./confstatuuF913/subs-3.sed line 16: Unterminated `s' command
> config.status: creating port/cpl_config.h
> config.status: port/cpl_config.h is unchanged
> GDAL is now configured for i686-pc-linux-gnu
> GDALmake.opt is empty!?
> It is no problem to build gdal-1.2.3 and it is also no problem to
> build newer versions than 1.2.3 on debian with gcc-2.95.
> I hope to get Mr.SID support compiled successfully into the newer
> versions, because this files on 1.2.3 and earlier.
Benjamin,
This is a bug with the mysql autoconfiguration logic.
Just add --without-mysql to the configure line. This
should be fixed in CVS though, apparently the fix did
not make it into the 1.2.5 version.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
