CLASS in raster layer (Was: Mapscript - problem with binary grid (ADF))
Bart van den Eijnden bartvde at XS4ALL.NL
Sat Oct 30 13:11:44 EDT 2004
Hi Marcin,
okay then I misunderstood your question ...
I ran into the same problem in August 2004 (the thread is called raster
legends). Paul Spencer then suggested using KEYIMAGE but I never gave it a
BTW: a shame you can't google the new listserv for the Mapserver mailing
list (or am I missing something?), I even don't know if linking to a
message will work, I'll give it a try though:
This was the thread I am referring to:;match;matches&z=4
Best regards,
On Sat, 30 Oct 2004 18:50:19 +0200, Marcin Zajączkowski <mszpak at WP.PL>
> Dnia 2004-10-30 18:04, Użytkownik Bart van den Eijnden napisał:
>> Hi,
>> did you already read the Raster HOWTO document?
> Yes, I read it. But in my case raster has its own colors (it's something
> like hipsometrial map (map contains level of ground - I don't know how
> it is in English)) and I wouldn't have to defines these levels on my
> own. I wanted to declare it (class) only to use in legend.
> Regards
> Marcin
Using Opera's revolutionary e-mail client:
