Label problem
GIRAUD Pierre bluecarto at FREE.FR
Wed Sep 1 05:01:11 EDT 2004
Hello,
Jacob is probably right. There is no sense that your LABEL object has a
CLASS object in it. Maybe, it's the good reason why you can't print labels.
Hierarchicaly, you should have :
LAYER
    LABELITEM
    CLASS
       LABEL
       END
    END
END
Pierre GIRAUD
camptocamp.com
Tony Jolibois wrote:
> -------- Original Message --------
> Subject:      Label problem
> Date:         Mon, 30 Aug 2004 15:46:48 +0200
> From:         Thomas Selliez <thomas.selliez at cls.fr>
> To:   Tony Jolibois <tjolibois at cls.fr>
> Hi list,
> I try to display labels on point layer (buoy aquisition date and town
> name) but I don't success... I give you a part of my mapfile, what's
> wrong ??
> Maybe somebody could help me...
> Thank you
> Thomas
> MAP
>   NAME           Ex_geo_tom
>   IMAGETYPE      png
>   #EXTENT         -180.000000 -90 180.000000 90   #vue du Monde
>   #EXTENT         -6.215625 43.121250 -5.090625 43.965   #vue Gijon et
> alentours
>   EXTENT         -18 36 0 52   #Espagne, Portugal, France
>   SIZE           800 600
>   SHAPEPATH      "/var/www/html/tutorial/data"
>   SYMBOLSET      "../tutorial/symbols/symbols35.sym"
>   FONTSET        "../tutorial/fonts/fonts.list"
>   CONFIG DODS_BLOCK_ORIENTED "1"
>   CONFIG DODS_AIS_FILE "/var/www/html/temp/ocean_ais.xml"
>   UNITS DD
>   WEB
>     TEMPLATE  'template_tom.html'
>     IMAGEPATH '/tmp/'
>     IMAGEURL  '/tmp/'
>   END
>   SYMBOL
>    NAME "po"
>    TYPE ellipse
>    FILLED true
>    POINTS
>     1 1
>    END
>   END
>   PROJECTION
>     #"proj=latlong"
>   END
>   SCALEBAR
>     STATUS EMBED
>     OUTLINECOLOR 0 0 0
>     IMAGECOLOR 255 255 255
>     TRANSPARENT FALSE
>     UNITS KILOMETERS
>     INTERVALS 1
>     SIZE 70 3
>     STYLE 1
>     POSITION LR
>     INTERLACE TRUE
>     POSTLABELCACHE true
>     LABEL
>       TYPE BITMAP
>       SIZE SMALL
>       OFFSET 0 0
>       BUFFER 0
>       MINDISTANCE -1
>       MINFEATURESIZE -1
>       COLOR 0 0 0
>       PARTIALS TRUE
>       FORCE FALSE
>     END
>   END
> #-------------PAYS------------------------
>  LAYER # shape Espagne
>     NAME         Espagne
>     DATA         ./Europe/Espagne/PONET_poly_poly
>     STATUS       default
>     TYPE         POLYGON
>  #--------------VILLES-------------------
>  LAYER # villes Espagne
>     NAME         VillesEspagne
>     DATA         ./Europe/Espagne/AEPOINT_point_point
>     STATUS       OFF
>     TYPE         POINT
>     MAXSCALE 10000000
>     CLASS
>       SYMBOL "po"
>       SIZE 6
>       COLOR 0 255 0
>     END
>     PROJECTION
>     "proj=latlong"
>     END
>    * LABELITEM "Aeptname"
>     CLASS
>         LABEL
>         TYPE truetype
>         FONT arial
>         SIZE 5
>         ANTIALIAS TRUE
>         COLOR 255 0 0
>         OUTLINECOLOR 255 255 255
>  PARTIALS false
>       END
> *    END
>   END # fin villes Espagne
> #--------------HYDRO-----------------------
> LAYER # hydro Espagne
>     NAME         HydroEspagne
>     DATA         ./Europe/Espagne/DNNET_arc_arc
>     STATUS       OFF
>     TYPE         LINE
>     MAXSCALE 10000000
> CLASS
>   color 0 0 255
> END
> END #fin hydro Espagne
> *LAYER # bouees
>     NAME         bouees_180
>     DATA         bouees_180
>     STATUS       OFF
>     TYPE         POINT
>     MAXSCALE 5000000
>     PROJECTION
>     "proj=latlong"
>     END
>     CLASS
>       SYMBOL "po"
>       SIZE 6
>       COLOR 255 0 0*
> *   END
> *    LABELITEM "DATE"
>     CLASS
>       LABEL
>         COLOR 132 31 31
>         SHADOWCOLOR 218 218 218
>         SHADOWSIZE 2 2
>         TYPE TRUETYPE
>         FONT arial-bold
>         SIZE 5
>         ANTIALIAS TRUE
>         POSITION CL
>         PARTIALS FALSE
>         MINDISTANCE 1*
> *        BUFFER 1
>       END # end of label
>     END
> *  END # fin bouees*
> END # end of map file
