Need help to compile mapserver-4.2.2 under windows
Brent Fraser bfraser at GEOANALYTIC.COM
Wed Sep 1 11:50:46 EDT 2004
Some notes on compiling Mapserver 4.2.2 on Windows:
Regex:
    Around line 419 of Mapserver 4.2.2 nmake .opt file, change:
REGEX_OBJ=$(REGEX_DIR)\regex.obj
    to
REGEX_OBJ=$(REGEX_DIR)\regex.obj $(REGEX_DIR)\test\printchar.obj
GD v2.0.28
   I haven't figured out how to compile this version of GD yet.  They've
changed their method of function decoration and  VC++ 6 refuses to compile
it (which is strange since their changes seem to be specifically for
Windows;  I'm sure I just need to set some compiler option).  For now I use
your method of downloading the binary package.
SQL Errors
Your "SQL" errors may be due to different settings in GDAL's nmake.opt and
Mapserver's nmake.opt.  Check to make sure both have the same value for
ODBC_SUPPORTED.
When your compile is successful, mapserv.exe will be created (and other
exes), and libmap.dll
The Mapserver compile How-to explains about some of the executables and
dlls.
Brent Fraser
----- Original Message -----
To: <MAPSERVER-USERS at LISTS.UMN.EDU>
Sent: Wednesday, September 01, 2004 8:48 AM
Subject: [UMN_MAPSERVER-USERS] Need help to compile mapserver-4.2.2 under
windows
> We have to use it under windows and need to compile it by changing some
> parameters. I am following the instruction "MapServer Win32 Compilation
and
> Installation HOWTO"(a little bit old) and the reame.win32 file coming from
> mapserver downloaded source file of version mapserver-4.2.2. I can
> successfully compiled some supporting libraries such as gdal-1.2.1 /
> freetype-2.1.3 / curl-7.12.1 / proj-4.4.8 /zlib121. The other libraries
> like GD library I can't compile it (no make file for windows)instead I
> downloaded a binary DLL version gd-2.0.28 and used "makemsvcimport.bat" to
> build bgd.lib . I can't compile REGEX library neither (no make file for
> windows) but I found one version from internet which is win32 port of GNU
> REGEX. Now I modified the nmake.opt file to comment unnecessary optional
> lines and then change the libraries path to point to my real libraries
> location. I run "nmake /f Makefile.vc" and got error in the end as the
> following. I hit the wall and and can't figure out which library is wrong
> or missing. Could somebody in this user group help me out? I really
> appreciate your help.
> ========= compiler error message ========
>   Creating library mapserver_i.lib and object mapserver_i.exp
> LINK : warning LNK4098: defaultlib "MSVCRT" conflicts with use of other
> libs; use /NODEFAULTLIB:library
> regex.obj : error LNK2001: unresolved external symbol _printchar
> cpl.lib(cpl_odbc.obj) : error LNK2001: unresolved external symbol
> _SQLFreeEnv at 4
> _SQLFreeConnect at 4
> _SQLDisconnect at 4
> _SQLError at 32
> _SQLConnect at 28
> _SQLSetConnectOption at 12
> _SQLAllocConnect at 8
> _SQLAllocEnv at 4
> _SQLAllocStmt at 8
> _SQLFreeStmt at 8
> _SQLExecDirect at 12
> _SQLDescribeCol at 36
> _SQLNumResultCols at 8
> _SQLGetData at 24
> _SQLFetchScroll at 12
> _SQLFetch at 4
> _SQLColumns at 36
> _SQLPrimaryKeys at 28
> _SQLTables at 36
> libmap.dll : fatal error LNK1120: 20 unresolved externals
> NMAKE : fatal error U1077: 'link' : return code '0x460'
> Stop.
> I tried "nmake /f Makefile.vc" again right after the above failure and got
> different:
>         link /NODEFAULTLIB:msvcrt /NODEFAULTLIB:libcd /DEBUG mapserv.obj
> mapserver_i.lib D:\Projects\mapserver_libraries\gdwin32\bgd.lib
> D:\Projects\mapserver_libraries\libpng\libpng.lib
> D:\Projects\mapserver_libraries\zlib121src\zlib.lib
> D:\Projects\mapserver_libraries\freetype-2.1.3\objs\freetype211ST_D.lib
> D:\Projects\mapserver_libraries\proj-4.4.8\src\proj.lib
> D:\Projects\mapserver_libraries\gdal-1.2.1\ogr\ogrsf_frmts\ogrsf_frmts.lib
> \ogr\ogrsf_frmts\ogrsf_frmts_sup.lib D:\Projects\mapserver_libraries\gdal-
> 1.2.1\ogr\ogr.lib D:\Projects\mapserver_libraries\gdal-1.2.1
> \ogr\..\port\cpl.lib D:\Projects\mapserver_libraries\gdal-1.2.1\gdal_i.lib
> D:\Projects\mapserver_libraries\curl-7.12.1\lib\libcurl.lib "C:\Program
> Files\Microsoft Visual Studio\VC98\Lib\WSOCK32.LIB"
> Microsoft (R) Incremental Linker Version 6.00.8168
> Copyright (C) Microsoft Corp 1992-1998. All rights reserved.
> mapserv.obj : error LNK2001: unresolved external symbol _regfree
> mapserv.obj : error LNK2001: unresolved external symbol _regcomp
> mapserv.obj : error LNK2001: unresolved external symbol _regexec
> mapserv.exe : fatal error LNK1120: 3 unresolved externals
> Stop.
> It seems mapserver.lib and mapserver_i.lib were created but no exe file
> there. What are expected files be generated if compile process is
> successful? Why do I see the map server binary distribution has bunch of
> DLLs there and many exe files in bin folder? Will I get the same result?
