Can ArcIMS consume WMS/WFS services?
Andrew Haigh
andrew at ANDREWHAIGH.NET
Wed Sep 1 14:03:36 EDT 2004
Yeah, it's a bit of a joke!
None of the Arc version 9 products support WMS / WFS / WCS.
Andrew
On 1 Sep 2004, at 14:25, Judd, Chris wrote:
> Paul,
> You're right. Here is the response from my ESRI support request.
> In answer to your question about whether ArcIMS accepts WMS services
> as an
> input the answer is that it can not. This is a feature that others
> have
> expressed interest in and the request does have a tracking id of
> CQ00239065.
> The problem is that it does require pretty significant work to the
> spatial
> server and some re-architecting of the spatial server. Right now work
> isn't
> being undertaken, but it isn't off the radar either.
> I have added your interest for this functionality to the
> request.
> One approach is to use cascading style sheets in your web
> application
> to layer two WMS output images from different sources on top of one
> another
> with the top one having a transparent background.
> Another approach is that ArcMap Server does serve up data from
> other
> IMS servers (though not WMS, not even with the interoperability
> extension).
> So if the other site you want to serve up is an ArcIMS site you may be
> able
> to consume their service through ArcMap Server.
> Bummer.
> Chris
> -----Original Message-----
> From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU]On
> Behalf Of Paul Ramsey
> Sent: Tuesday, August 31, 2004 9:10 PM
> To: MAPSERVER-USERS at LISTS.UMN.EDU
> Subject: Re: [UMN_MAPSERVER-USERS] Can ArcIMS consume WMS/WFS services?
> Probably a question best directed to an ESRI representative.
> My best knowledge is that currently the answer is "no", ArcIMS can only
> "cascade" against ArcMap web services.
> Paul
> On Tuesday, August 31, 2004, at 12:56 PM, Judd, Chris wrote:
>> List folks,
>> We are interested in ArcIMS (we are currently running version 4.0.1)
>> consuming a WMS/WFS compliant data service. We know that ArcIMS can
>> serve
>> WMS/WFS compliant data services, but can it consume it?
>> Thanks for your help,
>> Chris Judd
>> Florida Department of Environmental Protection
> Paul Ramsey
> Refractions Research
> Email: pramsey at refractions.net
> Phone: (250) 885-0632
