Need help to compile mapserver-4.2.2 under windows
Jingyu Bai
baijingyu at HOTMAIL.COM
Thu Sep 2 10:57:53 EDT 2004
Thanks your guys help again. I actually have the option you mentioned in my
makefile.vc like the following:
OPTFLAGS = /nologo /Zi $(WARNING_LEVEL) $(DEBUG)
BASE_CFLAGS = $(OPTFLAGS) -DWIN32 -D_WIN32
LDFLAGS =
/NODEFAULTLIB:MSVCRT /NODEFAULTLIB:libcd /NODEFAULTLIB:libcmtd /NODE
FAULTLIB:msvcrtd /NODEFAULTLIB:LIBC
#LDFLAGS = /NODEFAULTLIB:msvcrt /NODEFAULTLIB:libcd /DEBUG
#LDFLAGS = /NODEFAULTLIB:libcd /DEBUG
I now changed my namek.opt file to try the minimum compile case(just use GD
and regex/libpng/zlib)and comment out other lib options and changed the
gdal.pdb copy line in makefile.vc file but still got error though different
as the one I had yesterday. I don't know which library defines function
_strcasecmp and _strlcat. I searched GD src and redex src but find nothing
not find it in c++ standard lib string.h file neither. Another thing I
worried about is that I used binary GD version with generated lib myself by
using bat command "makemsvcimport.bat" from gdwin32 latest version 2.0.28
which is just a DLL mapping lib file not real static library. I then change
the namke.opt line "# GD include and library" from $(GD_DIR)/gd.lib to
$(GD_DIR)/gdd.lib since the bat file generated gbd.lib not gd.lib. Is this
a problem or do I have to compile GD source by myself in order to use GD
library correctly and how if required to do so? I appreciate your guys
help!
======== error msg from minimum map server nmake options run ========
maptime.obj : warning LNK4042: object specified more than once; extras
ignored
link /dll /debug mapbits.obj maphash.obj mapshape.obj
mapxbase.obj mapparser.obj maplexer.obj mapindex.obj maptree.obj
mapsearch.obj mapstring.obj mapsymbol.obj mapfile.obj maplegend.obj
maputil.obj mapscale.obj mapquery.obj maplabel.obj maperror.obj
mapprimitive.obj mapproject.obj mapraster.obj cgiutil.obj mapsde.obj
mapogr.obj maptime.obj maptemplate.obj mappostgis.obj maplayer.obj
mapresample.obj mapwms.obj mapwmslayer.obj mapgml.obj
maporaclespatial.obj mapprojhack.obj mapdraw.obj mapgd.obj mapoutput.obj
mapswf.obj mapgdal.obj mapwfs.obj mapwfslayer.obj mapows.obj maphttp.obj
mappdf.obj mapcontext.obj mapdrawgdal.obj mapjoin.obj mapgraticule.obj
mapmygis.obj mapimagemap.obj mapcopy.obj mapogcfilter.obj mapogcsld.obj
maptime.obj mapthread.obj D:\Projects\mapserver_libraries\temp\regex-0.12
\regex.obj D:\Projects\mapserver_libraries\gdwin32\bgd.lib
D:\Projects\mapserver_libraries\libpng\libpng.lib
D:\Projects\mapserver_libraries\zlib121src\zlib.lib /o
ut:libmap.dll /implib:mapserver_i.lib
Microsoft (R) Incremental Linker Version 6.00.8168
Copyright (C) Microsoft Corp 1992-1998. All rights reserved.
ignored
ignored
Creating library mapserver_i.lib and object mapserver_i.exp
mapoutput.obj : error LNK2001: unresolved external symbol _strcasecmp
mapjoin.obj : error LNK2001: unresolved external symbol _strcasecmp
mapimagemap.obj : error LNK2001: unresolved external symbol _strcasecmp
mapogcsld.obj : error LNK2001: unresolved external symbol _strcasecmp
mapraster.obj : error LNK2001: unresolved external symbol _strcasecmp
maptemplate.obj : error LNK2001: unresolved external symbol _strcasecmp
mapdraw.obj : error LNK2001: unresolved external symbol _strcasecmp
mapgd.obj : error LNK2001: unresolved external symbol _strcasecmp
maphash.obj : error LNK2001: unresolved external symbol _strcasecmp
mapxbase.obj : error LNK2001: unresolved external symbol _strcasecmp
mapstring.obj : error LNK2001: unresolved external symbol _strcasecmp
mapfile.obj : error LNK2001: unresolved external symbol _strcasecmp
mapfile.obj : error LNK2001: unresolved external symbol _strncasecmp
maputil.obj : error LNK2001: unresolved external symbol _strncasecmp
mapoutput.obj : error LNK2001: unresolved external symbol _strncasecmp
mapogcsld.obj : error LNK2001: unresolved external symbol _strncasecmp
maptemplate.obj : error LNK2001: unresolved external symbol _strlcat
libmap.dll : fatal error LNK1120: 3 unresolved externals
NMAKE : fatal error U1077: 'link' : return code '0x460'
Stop.
D:\Projects\mapserver-4.2.2>
====== My namke.opt file with minimum options ===
# nmake.opt - MapServer 4.x configuration for MSVC++
# This VC++ configuration is used in building MAPSERVER.LIB, MAPSERV.EXE,
# and the other MapServer command-line programs.
# To use the makefile:
# - Open a DOS prompt window
# - Run the VCVARS32.BAT script to initialize the VC++ environment
variables
# - Start the build with: nmake /f makefile.vc
# $Id: nmake.opt,v 1.4.2.1 2004/07/23 04:45:13 sdlime Exp $
# Contents:
# Section I: Mapserver Options (you may want to edit)
# Section II: Support Libraries (you must edit)
# Section III: Debug Flags (no need to edit)
# Section IV: Variable Setup (should not need to edit)
# Section V: UMN GIS System Setup (should not need to edit)
# Section VI: Collect compiler flags
MS_LIB = mapserver.lib
MS_LIB_DLL = mapserver_i.lib
# Uncomment the following to link mapserv.exe withh dll
DLLBUILD=1
# Input raster format options:
# The lite version of mapserver 4.x supports only PNG and JPEG data for
input.
# If you wish to support any of the following raster formats you will need
# the GDAL support library from http://www.remotesensing.org/gdal.
# Once you have the library, set the flag below to compile with GDAL and
# provide the full path to GDAL project directory
# Format Name
# Arc/Info ASCII Grid AAIGrid
# Arc/Info Binary Grid (.adf) AIG
# Microsoft Windows Device Independent Bitmap (.bmp) BMP
# BSB Nautical Chart Format (.kap) BSB
# CEOS (Spot for instance) CEOS
# First Generation USGS DOQ (.doq) DOQ1
# New Labelled USGS DOQ (.doq) DOQ2
# Military Elevation Data (.dt0, .dt1) DTED
# ERMapper Compressed Wavelets (.ecw) ECW
# ESRI .hdr Labelled EHdr
# ENVI .hdr Labelled Raster ENVI
# Envisat Image Product (.n1) Envisat
# EOSAT FAST Format FAST
# FITS (.fits) FITS
# Graphics Interchange Format (.gif) GIF
# Arc/Info Binary Grid (.adf) GIO
# GRASS Rasters GRASS
# TIFF / GeoTIFF (.tif) GTiff
# Hierarchical Data Format Release 4 (HDF4) HDF4
# Erdas Imagine (.img) HFA
# Atlantis MFF2e HKV
# Japanese DEM (.mem) JDEM
# JPEG2000 (.jp2, .j2k) JPEG2000
# JPEG2000 (.jp2, .j2k) JP2KAK
# NOAA Polar Orbiter Level 1b Data Set (AVHRR) L1B
# Atlantis MFF MFF
# NITF NITF
# OGDI Bridge OGDI
# PCI .aux Labelled PAux Yes
# Netpbm (.ppm,.pgm) PNM Yes
# USGS SDTS DEM (*CATD.DDF) SDTS
# SAR CEOS SAR_CEOS
# USGS ASCII DEM (.dem) USGSDEM
# X11 Pixmap (.xpm) XPM
#sdf
#GDAL=-DUSE_GDAL
#GDAL_DIR=D:\Projects\mapserver_libraries\gdal-1.2.1
# Input vector format options
# The lite version of Mapserver 4.x only suports ESRI shapefiles for input.
# If you wish to support any of the following vector formats you will need
# the GDAL support library with OGR from http://www.remotesensing.org/gdal.
# Once you have the library, set the flag below to compile with OGR and
# Format Name
# Arc/Info Binary Coverage
# FMEObjects Gateway
# IHO S-57 (ENC)
# Mapinfo File
# Microstation DGN
# OGDI Vectors
# Oracle Spatial
# PostgreSQL
# SDTS
# UK .NTF
# U.S. Census TIGER/Line
#sdf
#OGR=-DUSE_OGR
#ECW support
#ECW is one of the formats supported through GDAL. If you have built
#gdal with ECW support, you need to link it with the ECW librarires.
#uncommnet the following lines to have the ECW support.
#ECW_DIR= C:\projects\ECW_SDK
#Xerces support
#If GDAL was compoiled with the Xerces support, you need to use the
#xerces library. #uncommnet the following line to have the Xerces support
#XERCES_DIR = c:\projects\xerces-c1_6_0-win32
# Comment out the following to disable ODBC support.
#sdf
#ODBC_SUPPORTED = 1
# Tiff Input
# Tiff input is also available through GDAL. If you wish to build to support
# TIFF input without GDAL you will need to unccomment the following flag
# and set the full path to the project directory containing libtiff.
# See http://www.libtiff.org/ for support library
#TIFF=-DUSE_TIFF
#TIFFDIR=c:/my_path_to/tiff-v3.5.4
# JPEG Input:
# JPEG input for raster layers is also available through GDAL, If you wish
# to build support for JPEG without GDAL, uncomment the following flag
# and provide the full path to the jpeg support library project directory.
# See http://www.ijg.org/ for support library.
#JPEG=-DUSE_JPEG
#JPEG_DIR=D:\Projects\mapserver_libraries\gdal-1.2.1\frmts\jpeg\libjpeg
# Output format options:
# If you wish to allow JPEG output maps, uncomment the following flag
#sdf
#OUTPUT_JPEG=-DUSE_GD_JPEG
# If you wish to allow PNG output maps, uncomment the following flag
# and provide the full path to the png and zlib support library project
# directories.
# See http://www.libpng.org/pub/png/libpng.html for support library.
# See http://www.gzip.org/zlib/ for support library.
#sdf
OUTPUT_PNG=-DUSE_GD_PNG
PNG_DIR=D:\Projects\mapserver_libraries\libpng
ZLIB_DIR=D:\Projects\mapserver_libraries\zlib121src
# If you wish to allow Windows BMP output maps, uncomment the following
flag.
#OUTPUT_WBMP=-DUSE_GD_WBMP
# If you wish to have FLASH output, uncomment the following flag and provide
# the full path to the MING support library project directory.
# See http://ming.sourceforge.net/ for support library.
#MING=-DUSE_MING_FLASH
#MING_DIR=c:/projects/ming-0.2a
#MING_DIR=c:/projects/ming-0.3beta1
# If you wish to have PDF output, uncomment the following flag and provide
the
# full path to the PDF support library project directory.
# See http://www.pdflib.com/ for support library.
#PDF=-DUSE_PDF
#PDF_DIR=c:/projects/pdflib-4.0.3
# Annotation fonts.
# If you wish to annotate your maps with true type fonts unccomment the
# following flag. Provide the full path to the FreeType 2.x external
# supprt library. See http://www.freetype.org for support library.
#sdf
#ANNOTATION_FT=-DUSE_GD_FT
#FT_DIR=D:\Projects\mapserver_libraries\freetype-2.1.3
# Direct connectivity to Postgresql PostGIS.
# To turn on direct connectivity to Postgresql PostGIS uncomment the
following
# flag and set the full path name to the project directory for the
# Postgresql native Win32 client library.
# See http://www.postgresql.org for support library.
#POSTGIS =-DUSE_POSTGIS
#POSTGIS_DIR =c:/projects/libpq
#Orcale
#ORACLE_DIR = c:\Oracle\Ora81
#ORACLE=-DUSE_ORACLESPATIAL
#OGDI
#OGDI_DIR = c:\projects\ogdi-3.1.0
#OGDI_LIB = $(OGDI_DIR)\lib\ogdi31.lib
# Direct connectivity to ArcSDE.
# To turn on direct connectivity to ArcSDE uncomment the following
# flag and set the full path name to the project directory for ArcSDE.
# Since ESRI includes the version number in the name of their libraries
# you may need to change that number in Section III of this configuration
# file.
# See http://www.esri.com/software/arcgis/arcinfo/arcsde/index.html for
# support library
#SDE_OPT=-DUSE_SDE -DWIN32
#SDE_DIR=c:/my_path_to/arcsde
# EPPL7 Support
# This activates ERDAS as well. It is included in the distribution.
# Probably the best raster alternative if
# you've got EPPL7 laying around. See http://www.lmic.state.mn.us/ for
# more information.
# Uncomment out the following flag and set the full path name to the
# epplib.obj file.
#EPPL=-DUSE_EPPL
#EPPL_OBJ=c:/my_path/epplib.obj
# If you want to ignore missing datafile errors uncomment the following
# line. This is especially useful with large tiled datasets that may not
# have complete data for each tile.
#sdf
#IGNORE_MISSING_DATA=-DIGNORE_MISSING_DATA
#NEED_NONBLOCKING_STDERR=-DNEED_NONBLOCKING_STDERR
#ENABLE_STDERR_DEBUG=-DENABLE_STDERR_DEBUG
# If you want antialiasing (note that It requires gd2)
#sdf
#USE_GD_ANTIALIAS=-DUSE_GD_ANTIALIAS
# Use this flag to compile with WMS Server support.
# To find out more about the OpenGIS Web Map Server Specification go to
# http://www.opengis.org/
#sdf
#WMS=-DUSE_WMS_SVR
# Use this flag to compile with WMS Client support. WMS Client support
# allows you to pull layers from other OGIS WMS servers on the interent and
# incorporate them into your map.
# you need the libcurl library from http://curl.haxx.se/library/c/
# Set the full path to the curl project directory.
# You will also need to set the full path to the Microsoft Visual C++
windows
# socket library.
#WMSCLIENT= -DUSE_WMS_LYR
#CURL_DIR=c:/projects/curl-7.10.2
#CURL_DIR=D:\Projects\mapserver_libraries\curl-7.12.1
#WINSOCK_LIB = "C:\Program Files\Microsoft Visual Studio\VC98
\Lib\WSOCK32.LIB"
# Use -DUSE_WFS_SVR to compile with WFS server support, requires OGR and
PROJ4
# Use -DUSE_WFS_LYR to compile with WFS client support, requires libcurl
#WFS=-DUSE_WFS_SVR
#WFSCLIENT= -DUSE_WFS_LYR
# Reprojecting.
# If you would like mapserver to be able to reproject data from one
# geographic projection to another, uncomment the following flag
# Proj.4 distribution (cartographic projection routines).
# Not required for normal use. (EXPERIMENTAL)
# For PROJ_DIR use full path to Proj.4 distribution
#PROJ=-DUSE_PROJ -DUSE_PROJ_API_H
#PROJ_DIR=D:\Projects\mapserver_libraries\proj-4.4.8
# PHP Mapscript.
# If you plan to build PHP mapscript uncomment the following flag and
# set the full path to the PHP project directory
#PHP=1
#PHP_DIR=D:/php4.3.4
# Apparently these aren't as commonplace. Edit the
# following line to reflect the missing functions on your platform.
#STRINGS=-DNEED_STRCASECMP -DNEED_STRNCASECMP -DNEED_STRDUP
#STRINGS=-DNEED_STRCASECMP -DNEED_STRNCASECMP -DNEED_STRLCAT
# Section II: External Support Libraries
# You will need to set the paths to various support library projects
# that you have compiled.
# GD Library.
# Mapserver 4.x only supports GD 2.x and greater.
# Sorry no more GIF support. If you need GIF support you will
# need to run Mapserver 3.6.x with GD 1.2.
# GD is a required support library for MapServer 4.x.
# Enter the full path to your GD 2.x project directory
# Note : A patched version of GD that supports GIF, JPEG, PNG and WBMP can
be
# downloaded from http://www.rime.com.au/gd/. If you are using this library,
#you should uncomment the following line
OUTPUT_GIF=-DUSE_GD_GIF -DGD_HAS_GDIMAGEGIFPTR
GD_DIR=D:\Projects\mapserver_libraries\gdwin32
# REGEX Libary
# VC++ does not include the REGEX library... so we must provide our one.
# The following definitions will try to build GNU regex-0.12 located in the
# regex-0.12 sub-directory.
# If it was not included in the source distribution, then you can get it
# ftp://ftp.gnu.org/pub/gnu/regex/regex-0.12.tar.gz
# Provide the full path to the REGEX project directory
# You do not need this library if you are compiling for PHP mapscript.
# In that case the PHP regex library will be used instead
!IFNDEF PHP
REGEX_DIR=D:\Projects\mapserver_libraries\temp\regex-0.12
!ENDIF
# Section III: Debug flags
# Should not need to be updated.
# DEBUG Build flags
# Set the DEBUG flag if you wish to make a debug build
DEBUG=/DDEBUG
# Set the Warning level for the compiler (defaults to W1)
WARNING_LEVEL=/W3
# Set the linker debug option
LDEBUG=/debug
# Proj.4 include and library
!IFDEF PROJ_DIR
PROJ_INC=-I$(PROJ_DIR)\src
PROJ_LIB=$(PROJ_DIR)\src\proj.lib
!ENDIF
# CURL include and library
!IFDEF WMSCLIENT
CURL_INC = -I$(CURL_DIR)\include
CURL_LIB = $(CURL_DIR)\lib\libcurl.lib
!ENDIF
# Set the jpeg library
!IFDEF OUTPUT_JPEG
JPEG_LIB=$(JPEG_DIR)\libjpeg.lib
!ENDIF
# Set the png support libaries
!IFDEF OUTPUT_PNG
PNG_LIB=$(PNG_DIR)\libpng.lib $(ZLIB_DIR)\zlib.lib
!ENDIF
# Set the FreeType library
!IFDEF ANNOTATION_FT
#FT_LIB=$(FT_DIR)/objs/freetype211.lib
FT_LIB=$(FT_DIR)\objs\freetype211ST_D.lib
!ENDIF
GD_INC= -I$(GD_DIR)
GD_LIB= $(GD_DIR)\bgd.lib \
$(JPEG_LIB) $(PNG_LIB) $(FT_LIB)
GD= $(OUTPUT_PNG) $(OUTPUT_JPEG) $(OUTPUT_WBMP) $(OUTPUT_GIF)
$(ANNOTATION_FT)
# Tiff library on input
!IFDEF TIFF
TIFF_INC=-I$(TIFF_DIR)\tiff-v3.5.4\libtiff
TIFF_LIB=$(TIFF_DIR)\tiff-v3.5.4\libtiff\libtiff.lib
!ENDIF
# JPEG library on input
!IFDEF JPEG
!ENDIF
# Setup GDAL includes and libraries
!IFDEF GDAL
GDAL_INC = -I$(GDAL_DIR)\gcore -I$(GDAL_DIR)\alg
GDAL_LIB = $(GDAL_DIR)\gdal_i.lib
!ENDIF
# Setup OGR includes and libraries
!IFDEF OGR
OGR_INC = -I$(GDAL_DIR)\ogr\ogrsf_frmts -I$(GDAL_DIR)\ogr -I$(GDAL_DIR)
\ogr\..\port
OGR_LIB = $(GDAL_DIR)\ogr\ogrsf_frmts\ogrsf_frmts.lib $(GDAL_DIR)
\ogr\ogrsf_frmts\ogrsf_frmts_sup.lib $(GDAL_DIR)\ogr\ogr.lib $(GDAL_DIR)
\ogr\..\port\cpl.lib
!ENDIF
# Setup ESRI SDE support.
!IFDEF SDE_OPT
SDE_INC=-I$(SDE_DIR)\include
SDE_LIB=$(SDE_DIR)\lib\sde80.lib $(SDE_DIR)\lib\sg80.lib $(SDE_DIR)
\lib\pe80.lib
!ENDIF
#ECW support
!IFDEF ECW_DIR
ECW_LIB=$(ECW_DIR)\lib\NCSEcw.lib $(ECW_DIR)\lib\NCSEcwC.lib \
$(ECW_DIR)\lib\NCSUtil.lib
!ENDIF
#Xerces support
!IFDEF XERCES_DIR
XERCES_LIB=$(XERCES_DIR)/lib/xerces-c_1.lib
!ENDIF
!IFDEF ODBC_SUPPORTED
ODBC_LIB = "C:\Program Files\Microsoft Visual Studio\VC98\Lib\ODBC32.lib"
!ENDIF
# Setup REGEX object and includes
!IFNDEF PHP
REGEX_OBJ=$(REGEX_DIR)\regex.obj
REGEX_INC=-I$(REGEX_DIR)
!ELSE
REGEX_OBJ=$(PHP_DIR)\regex\regcomp.obj $(PHP_DIR)\regex\regerror.obj \
$(PHP_DIR)\regex\regexec.obj $(PHP_DIR)\regex\regfree.obj
REGEX_INC=-I$(PHP_DIR)\regex -DPHP_NO_ALIASES
!ENDIF
# REGEX needs some special flags... here they are for VC++ 6.0
REGEX_OPT=-DHAVE_STRING_H -DREGEX_MALLOC
# Setup Postgesql PostGIS includes and libs
# Note that the Postgresql includes are not used in the compilation of
# PHP/MapScript. The reason is that there is a name conflict between the
# regex/regex.h files used in PHP and Postgresql. This is not a real issue
# since they are two completely different interfaces. The issue arrises
when
# the php_regex.h trys to include regex/regex.h and gets the wrong one from
# postgresql. Therefore we do not give it that opertunity by not providing
the
# include path.
!IFDEF POSTGIS
!IFNDEF PHP_BUILD_CALL
#POSTGIS_INC=-I$(POSTGIS_DIR)/src/interfaces/libpq -
I$(POSTGIS_DIR)/src/include
POSTGIS_INC=-I$(POSTGIS_DIR)\interfaces\libpq -I$(POSTGIS_DIR)\include
!ENDIF
#POSTGIS_LIB=$(POSTGIS_DIR)\src\interfaces\libpq\release\libpqdll.lib
POSTGIS_LIB=$(POSTGIS_DIR)\interfaces\libpq\libpqdll.lib
POSTGIS_OBJ=mappostgis.obj
!ENDIF
# Setup FLASH includes and libs
!IFDEF MING
MING_INC=-I$(MING_DIR)\src -I$(MING_DIR)
MING_LIB= $(MING_DIR)\src\libming.lib
#MING_VERSION=-DMING_VERSION_03
!ENDIF
# Setup PDF includes and libs
!IFDEF PDF
PDF_LIB=$(PDF_DIR)\pdflib\pdflib.lib
PDF_INC=-I$(PDF_DIR)\pdflib
!ENDIF
#Oracle support
!IFDEF ORACLE
ORACLE_INC=-I$(ORACLE_DIR)\oci\include
ORACLE_LIB=$(ORACLE_DIR)\oci\lib\msvc\oci.lib
!ENDIF
# Section V: UMN GIS System Support
# UofMN GIS/Image Processing Extension (very experimental)
#EGIS=-DUSE_EGIS
!IFDEF EGIS
ERR_DIR=c:\my_path_to\errLog
ERR_OBJ=$(ERR_DIR)\errLog.o
ERR_INC=-I$(ERR_DIR)
ERR_LIB=-L$(ERR_DIR) -lerrLog
IMGGEN_DIR=c:\my_path_to\imgSrc
IMGGEN_OBJ=$(IMGGEN_DIR)\imgLib.o
IMGGEN_INC=-I$(IMGGEN_DIR)
IMGGEN_LIB=-L$(IMGGEN_DIR) -limgGEN
!ENDIF
#BY
SDF /NODEFAULTLIB:libcmt.lib /NODEFAULTLIB:msvcrt.lib /NODEFAULTLIB:libcd.li
b /NODEFAULTLIB:libcmtd.lib /NODEFAULTLIB:msvcrtd.lib
EXTERNAL_LIBS=$(GD_LIB) $(TIFF_LIB) $(JPEG_LIB) \
$(PROJ_LIB) $(OGR_LIB) $(GDAL_LIB)\
$(CURL_LIB) $(MING_LIB) $(PDF_LIB) \
$(WINSOCK_LIB) $(POSTGIS_LIB) $(IMGGEN_LIB) $(ERR_LIB) \
$(XERCES_LIB) $(ECW_LIB) $(ORACLE_LIB) $(OGDI_LIB) $(ODBC_LIB)
LIBS=$(MS_LIB) $(EXTERNAL_LIBS)
LIBS_DLL=$(MS_LIB_DLL) $(EXTERNAL_LIBS)
INCLUDES=$(GD_INC) $(TIFF_INC) $(JPEG_INC) \
$(PROJ_INC) $(REGEX_INC) $(GDAL_INC) $(OGR_INC) \
$(CURL_INC) $(MING_INC) $(PDF_INC) $(POSTGIS_INC) \
$(IMGGEN_INC) $(ERR_INC) $(ORACLE_INC)
MS_CFLAGS=$(INCLUDES) $(REGEX_OPT) $(STRINGS) $(POSTGIS) \
$(EPPL) $(PROJ) $(TIFF) $(JPEG) $(GD) $(OGR) $(WMS) \
$(WMSCLIENT) $(MING) $(IGNORE_MISSING_DATA)
$(NEED_NONBLOCKING_STDERR) \
$(GDAL) \
-DFEATURE_INFO_HTML $(WFS) $(WFSCLIENT) $(PDF) $(EGIS) \
$(USE_GD_ANTIALIAS) $(ORACLE) $(MING_VERSION)
=========== end of my minimum namke.opt file =============
