Need help to compile mapserver-4.2.2 under windows
Jingyu Bai
baijingyu at HOTMAIL.COM
Fri Sep 3 11:54:52 EDT 2004
Could you send me a regex.obj with debug info and make sure it is compiled
under /MTd option so I can use it under my compiler process. Now I just got
error after I re-compiler most other libraries with /MTd option. How should
I deal with GD library since I can't compile it and no control to use /MTd.
Do you mind to send me your GD library with /MTd to
baijingyu_ca at yahoo.com ? I really appreciate your help.
=== less error than yesterday ===
maptime.obj : warning LNK4042: object specified more than once; extras
ignored
ignored
Creating library mapserver_i.lib and object mapserver_i.exp
regex.obj : fatal error LNK1202: "D:\Projects\mapserver-4.2.3\vc60.pdb" is
missing debugging information for referencing module
NMAKE : fatal error U1077: 'link' : return code '0x4b2'
Stop.
