Equidistant cylindrical projection
Ben Lloyd-Hughes blh at MSSL.UCL.AC.UK
Fri Sep 3 12:52:07 EDT 2004
I'm having a terrible time trying to serve an image of an ESRI shape
file.  From ogrinfo I get:
$ ogrinfo -so CNTRY95_eqc.SHP CNTRY95_eqc
INFO: Open of `CNTRY95_eqc.SHP'
using driver `ESRI Shapefile' successful.
Layer name: CNTRY95_eqc
Geometry: Polygon
Feature Count: 258
Extent: (-10018753.533581, -10006731.666389) - (10018753.533581,
9308936.146330)
Layer SRS WKT:
PROJCS["World_Equidistant_Cylindrical",
    GEOGCS["GCS_WGS_1984",
        DATUM["WGS_1984",
            SPHEROID["WGS_1984",6378137.0,298.257223563]],
        PRIMEM["Greenwich",0.0],
        UNIT["Degree",0.0174532925199433]],
    PROJECTION["Equirectangular"],
    PARAMETER["False_Easting",0.0],
    PARAMETER["False_Northing",0.0],
    PARAMETER["Central_Meridian",0.0],
    PARAMETER["Standard_Parallel_1",60.0],
    UNIT["Meter",1.0]]
FIPS_CNTRY: String (2.0)
GMI_CNTRY: String (3.0)
ISO_CNTRY: String (3.0)
WB_CNTRY: String (3.0)
CNTRY_NAME: String (40.0)
EU: String (1.0)
FAO: String (1.0)
GA: String (1.0)
GA_MEMB_YR: Integer (4.0)
IAEA: String (1.0)
IBRD: String (1.0)
IMF: String (1.0)
OPEC: String (1.0)
SC: String (1.0)
UNESCO: String (1.0)
WHO: String (1.0)
WMO: String (1.0)
POP_CNTRY: Integer (10.0)
SQKM_CNTRY: Real (15.3)
SQMI_CNTRY: Real (15.3)
So far so good - then I have a MAP file:
MAP
  IMAGETYPE PNG
  UNITS METERS
  EXTENT  -10018753.533581 -10006731.666389 10018753.533581 9308936.146330
  SIZE 400 300
  SHAPEPATH "data"
  IMAGECOLOR 255 255 255
  PROJECTION
    "proj=eqc"
    "datum=WGS84"
    "elips=WGS84"
  END
  # Start of LAYER DEFINITIONS --------------------------------------------
  LAYER # States polygon layer begins here
    NAME CNTRY95_eqc
    DATA CNTRY95_eqc
    STATUS DEFAULT
    TYPE POLYGON
    PROJECTION
       "proj=eqc"
       "datum=WGS84"
       "elips=WGS84"
    END
   CLASS
      COLOR 232 232 232
      OUTLINECOLOR 32 32 32
    END
  END # States polygon layer ends here
  # End of LAYER DEFINITIONS -------------------------------
 END # end of map file/object
Which is invoked via cgi:
http://fuji-bgh.geol.ucl.ac.uk/cgi-bin/mapserv.exe?map=D%3A%2FApache%
2FApache2%2Fmywebdocs%2Fmaps%2Fdemos%2Fdrought%2Fdemo.map&mode=map
