USGS Urban133 Ortho Imagery via WMS
Thomas Chesky
thomaschesky at YAHOO.COM
Sat Sep 4 19:41:23 EDT 2004
I finally made it work (almost).
I have now some problem with reprojection.
I want to reproject to epsg:26910 but my linemap and reprojected USGS does not match.
If I reproject the linemap to 4326 it nicely overlays the 4326 default projection of the USGS ortho layer, but reprojecting both to 26910 does not work. I have the two layers in 2 different map file but it should not matter (when overlaying the graphics with photo sw)
Is there any special thing to know re: reprojecting raster layers?
Thanks in advance
Here is the working map file:
MAP
NAME USGSUrban
SHAPEPATH "/usr/local/mapdata/"
SIZE 600 400
IMAGETYPE PNG24
IMAGECOLOR 0 0 0
UNITS DD
PROJECTION
"init=epsg:26910"
END
WEB
METADATA
"wms_title" "Test"
"wms_onlineresource" "http://localhost:8080/cgi-bin/mapserv?map=/usr/local/mapapp/urban.map&"
"wms_srs" "EPSG:4269 EPSG:4326 EPSG:26910 EPSG:2227 EPSG:2926 EPSG:26911"
END
IMAGEPATH /usr/local/httpd/htdocs/tmp/
END
# SanFrancisco01, CA
# <LatLonBoundingBox minx="-122.631874313893" miny="37.1202124212771" maxx="-121.597707749044" maxy="38.2500104134292"/>
LAYER
NAME "SanFrancisco01"
TYPE RASTER
STATUS OFF
CONNECTION "http://gisdata.usgs.net:80/servlet/com.esri.wms.Esrimap/USGS_EDC_Ortho_133Urban?"
CONNECTIONTYPE WMS
METADATA
"wms_srs" "EPSG:4326"
"wms_name" "SanFrancisco01"
"wms_server_version" "1.1.0"
"wms_formatlist" "image/png,image/jpeg"
"wms_format" "image/png"
END
END
END # end of map file
"Swaminathan, Gayathri" <gayathri at OU.EDU> wrote:
Hi Thomas:
Here is an example....
### OKC 2002 Ortho USGS-WMS ###
LAYER
NAME Urban133
GROUP Imagery
TYPE RASTER
STATUS ON
MAXSCALE 500000
OFFSITE 255 255 255
CONNECTIONTYPE WMS
CONNECTION "http://gisdata.usgs.net:80/servlet/com.esri.wms.Esrimap?SERVICENAME=133urban&REASPECT=false&REQUEST=map"
#MINSCALE 500
PROJECTION
"init=epsg:4326" #WGS 84
END
TRANSPARENCY 20
METADATA
"NoID" "T"
"wms_name" "UA_ORTHO_302_01"
"wms_server_version" "1.0.0"
"wms_format" "png"
"wms_title" "USGS Urban Color Ortho 2002"
"wms_group_title" "Imagery"
"wms_style" ""
#"wms_extent" "-123.12987 45.241726 -122.3584 45.75648"
END
END
HTH,
Gayathri
-----Original Message-----
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On Behalf Of Thomas Chesky
Sent: Saturday, August 28, 2004 3:33 PM
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: [UMN_MAPSERVER-USERS] USGS Urban133 Ortho Imagery via WMS
Does anyone have a working mapfile which can produce the color, urban aerial maps using USGS's WMS interface? I just could not make it work :-(
WMS server is at http://gisdata.usgs.net:80/servlet/com.esri.wms.Esrimap?
Thanks in advance.
Thomas
Do you Yahoo!?
Yahoo! Mail is new and improved - Check it out!
Do you Yahoo!?
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20040904/39003289/attachment.html
