php mapscript compilation error
Sandeep Bashyal
gis at UNDPHAIS.ORG.NP
Mon Sep 6 08:17:24 EDT 2004
Hi
I am getting the following errors while installing php mapscript:
cd mapscript/php3; make; cd ../..
make[1]: Entering directory `/usr/local/mapserver-4.2.3/mapscript/php3'
gcc -fPIC -O2 -Wall -DCOMPILE_DL=1 -DPHP4 -DUSE_WMS_LYR -DUSE_WFS_SVR
-DUSE_WMS_SVR -DUSE_MYGIS -DUSE_GDAL -DUSE_OGR -DUSE_THREAD
-DUSE_PROJ -DUSE_PROJ_API_H -DUSE_PDF -DUSE_GD_GIF -DUSE_GD_PNG
-DUSE_GD_JPEG -DUSE_GD_WBMP -DUSE_GD_FT -DGD_HAS_GDIMAGEGIFPTR
-I/usr/local/mapserver-4.2.3 -I/usr/local/mysql/include
-I/usr/local/include -I/usr/local/include -I/usr/src/php-4.3.3
-I/usr/src/php-4.3.3/dl -I/usr/src/php-4.3.3/main
-I/usr/src/php-4.3.3/Zend -I/usr/src/php-4.3.3/include
-I/usr/src/php-4.3.3/TSRM -c -o php_mapscript_util.o php_mapscript_util.c
php_mapscript_util.c: In function `_phpms_fetch_handle2':
php_mapscript_util.c:153: warning: dereferencing type-punned pointer will
break strict-aliasing rules
php_mapscript_util.c: In function `_phpms_fetch_property_handle2':
php_mapscript_util.c:205: warning: dereferencing type-punned pointer will
php_mapscript_util.c: In function `_phpms_fetch_property_string':
php_mapscript_util.c:252: warning: dereferencing type-punned pointer will
php_mapscript_util.c: In function `_phpms_fetch_property_long':
php_mapscript_util.c:278: warning: dereferencing type-punned pointer will
php_mapscript_util.c: In function `_phpms_fetch_property_double':
php_mapscript_util.c:311: warning: dereferencing type-punned pointer will
php_mapscript_util.c: In function `_phpms_fetch_property_resource':
php_mapscript_util.c:337: warning: dereferencing type-punned pointer will
php_mapscript_util.c: In function `_phpms_set_property_string':
php_mapscript_util.c:373: warning: dereferencing type-punned pointer will
php_mapscript_util.c: In function `_phpms_set_property_null':
php_mapscript_util.c:401: warning: dereferencing type-punned pointer will
php_mapscript_util.c: In function `_phpms_set_property_long':
php_mapscript_util.c:430: warning: dereferencing type-punned pointer will
php_mapscript_util.c: In function `_phpms_set_property_double':
php_mapscript_util.c:459: warning: dereferencing type-punned pointer will
php_mapscript_util.c: In function `_php_extract_associative_array':
php_mapscript_util.c:545: warning: dereferencing type-punned pointer will
-I/usr/src/php-4.3.3/TSRM -c -o php_mapscript.o php_mapscript.c
php_mapscript.c: In function `php3_ms_map_setExtent':
php_mapscript.c:1824: warning: dereferencing type-punned pointer will
php_mapscript.c: In function `_php3_ms_map_setProjection':
php_mapscript.c:1914: warning: dereferencing type-punned pointer will
php_mapscript.c: In function `php3_ms_map_zoomPoint':
php_mapscript.c:2433: warning: dereferencing type-punned pointer will
php_mapscript.c: In function `php3_ms_map_zoomRectangle':
php_mapscript.c:2730: warning: dereferencing type-punned pointer will
php_mapscript.c: In function `php3_ms_map_zoomScale':
php_mapscript.c:3072: warning: dereferencing type-punned pointer will
php_mapscript.c: In function `php3_ms_map_draw':
php_mapscript.c:3329: warning: dereferencing type-punned pointer will
php_mapscript.c: In function `php3_ms_map_drawQuery':
php_mapscript.c:3418: warning: dereferencing type-punned pointer will
php_mapscript.c: In function `php3_ms_map_setLayersDrawingOrder':
php_mapscript.c:4901: warning: dereferencing type-punned pointer will
php_mapscript.c: In function `php3_ms_map_loadMapContext':
php_mapscript.c:5572: warning: dereferencing type-punned pointer will
php_mapscript.c: In function `php3_ms_map_selectOutputFormat':
php_mapscript.c:5650: warning: dereferencing type-punned pointer will
php_mapscript.c: In function `php3_ms_img_free':
php_mapscript.c:6214: warning: dereferencing type-punned pointer will
php_mapscript.c: In function `php3_ms_point_free':
php_mapscript.c:9371: warning: dereferencing type-punned pointer will
php_mapscript.c: In function `php3_ms_line_free':
php_mapscript.c:9718: warning: dereferencing type-punned pointer will
php_mapscript.c: In function `php3_ms_shape_project':
php_mapscript.c:9969: warning: dereferencing type-punned pointer will
php_mapscript.c: In function `php3_ms_shape_free':
php_mapscript.c:10432: warning: dereferencing type-punned pointer will
php_mapscript.c: In function `php3_ms_rect_free':
php_mapscript.c:10954: warning: dereferencing type-punned pointer will
php_mapscript.c: In function `php3_ms_shapefile_free':
php_mapscript.c:11552: warning: dereferencing type-punned pointer will
php_mapscript.c: In function `php3_ms_projection_free':
php_mapscript.c:11701: warning: dereferencing type-punned pointer will
php_mapscript.c: In function `php3_ms_symbol_setPoints':
php_mapscript.c:12880: warning: dereferencing type-punned pointer will
php_mapscript.c:12889: warning: dereferencing type-punned pointer will
php_mapscript.c: In function `php3_ms_symbol_setStyle':
php_mapscript.c:13033: warning: dereferencing type-punned pointer will
Config parameters for mapserver:
./configure --without-tiff --without-eppl --with-threads --with-proj
--with-gdal=/usr/local/bin/gdal-config --with-ogr
--with-php=/usr/src/php-4.3.3 --with-freetype=/usr/bin --with-wmsclient
--with-wfs --with-wfsclient --with-mygis=/usr/local/mysql/bin/mysql_config
Php was built using:
./configure --enable-shared --with-regex=system --with-jpeg-dir=/usr
--with-png-dir=/usr --with-zlib --with-gd=/usr/local
--with-freetype-dir=/usr --enable-force-cgi-redirect --enable-dbase
--with-mysql=/usr/local/mysql --with-config-file-path=/usr/local/php433/
--prefix=/usr/local/php433
I'm new to mapserver and can't seem to figure out what I'm doing wrong.
Any help would be greatly appreciated.
Thanks in advance.
Sandeep Bashyal
National GIS Officer
Humanitarian Assistance Information System (HAIS)
United Nations (NEP/01/008)
UN House, Pulchowk
G.P.O. Box 107
Kathmandu, Nepal
Tel: (+977) 01 5543957
(+977) 01 5554304
Cell:(+977) 9841270854
Fax: (+977) 01 5528059
mailto:gis(at)undphais.org.np
mailto:sandeep(at)earthmapping.com
http://www.undp.org.np
