Aquire x/y coordinates from rectangle object
G-Net Consulting
joelf at GNETCONSULTING.COM
Tue Sep 7 13:24:17 EDT 2004
Lowell:
Thanks a bunch. I really appreciate the help.
Joel
----- Original Message -----
To: <MAPSERVER-USERS at LISTS.UMN.EDU>
Sent: Tuesday, September 07, 2004 12:04 PM
Subject: Re: [UMN_MAPSERVER-USERS] Aquire x/y coordinates from rectangle
object
> The following message was sent by Lowell Filak <lfilak at MEDINACO.ORG> on
> Tue, 7 Sep 2004 10:37:36 -0400.
>> The following message was sent by G-Net Consulting
>> <joelf at GNETCONSULTING.COM> on Sat, 4 Sep 2004 01:14:23 -0400.
>> > Hello List:
>> > I'm looking for a snippet of code to grab the X/Y coordinates
>> > from a point in a shape file. I've pulled the shape data in
>> > from the DBF (thanks to Lowell for that). Now I would like
>> > to display the data in overLib with a mouseover.
>> > So what is the best way to get the X/Y for each shape
>> > in the chosen extent?
>> > Thanks.
>> > Joel
>> Joel;
>> You can:
>> shapeObj = new shapeObj(type_point)
>> use the shapeindex from resultCacheMemberObj with
>> layer->getShape(shapeObj, 0, shapeindex)
>> pointObj=shapeObj->get(0)
>> pointObj->{x} & pointObj->{y}
>> The doc (at least swigmapscript) needs to be clearer on this.
>> Lowell
> Joel;
> Here's a correct example.
> $data = $layer->{data};
> $shapefile = new mapscript::shapefileObj($data,-1);
> $point = new mapscript::pointObj();
> $shapefile->getPoint(shapeindex,$point);
> $x = $point->{x};
> $y = $point->{y};
> Lowell
