Oracle Spatial
Eric Wright
eric.linux at SHAW.CA
Wed Sep 8 13:53:24 EDT 2004
Thanks for the info Fernando.
You hit the nail on the head with that one, the layers that are not showing up in my map are the 300x ones.
I used the Oracle shp2sdo tool to create the SQL and CTL files before running the sqlldr tool to load the layers. I then ran EXECUTE
SDO_MIGRATE.TO_CURRENT('TABLE','GEOMETRY_COLUMN'); on all the layers and then created indexes for each layer.
I am unable to manualy update the layer as Oracle complains that the "Layer Dimensionality does not match geometry dimensions" it makes sense that it won't let me do this.
I will have re-load the data from the shape files and drop the third dimension.
Do you or (anyone else) know if using the OGR tool ogr2ogr will load the layer in a format that is sutable for MapServer? (i.e. drop the z coordinate) If not I will have to write my own Oracle loader.
Thanks again.
Eric W
----- Original Message -----
Date: Tuesday, September 7, 2004 5:00 pm
Subject: Re: [UMN_MAPSERVER-USERS] Oracle Spatial
> Hi Eric,
> I belive that I can help you, your problem can be with the type
> of your data
> (SDO_GTYPE). THe Oracle Spatial driver for mapserver can't draw
> data if you
> stored using 3D definition. You can check this when you execute
> one simple query
> in sqlplus, if return something like 300x try to redefine this
> value to 200x.
> Only one question, how you import the data in Oracle, are you
> use the sqlldr?
> If yes, after you import the data do you execute the function "EXECUTE
> SDO_MIGRATE.TO_CURRENT('TABLE','GEOMETRY_COLUMN');" ? Are you
> create the spatial
> index?
> When you execute your mapserver using only the cgi definition
> using only the
> layer with oracle spatial connection what's happen? Ex:
> http://localhost/cgi-
> bin/mapserv?map=yourmap.map&mode=map&imgsize=400+400&layers=oraclelayer You can see one example in this site:
> http://g10novo.cttmar.univali.br/gtz/principal.php Everthing,
> polygons, lines
> and points in this example are stored in Oracle Spatial.
> With the label I didn't see anything about this problem when
> you use Oracle
> Spatial, are you define labelmaxscale in your layer? I saw
> something like as
> when I used projection definition, the points disappear with wrong
> projection. I don't know if I help you.
> If you need some help, you can report me.
> Fernando Simon - simon at inf.univali.br
> Database Manager, Mapserver and Oracle Spatial developer
> G10 - Laboratorio de Computacao Aplicada
> http://g10.cttmar.univali.br
> Quoting Eric Wright <eric.linux at SHAW.CA>:
> > Good morning,
> > I am working on a project with MapServer and Oracle Spatial.
> Both are running
> > under windows environments and I have noticed some odd behavior.
> > Some of the data that I have loaded into Oracle Spatial layers
> does not get
> > rendered by MapServer. I have run the Oracle test on the layers
> and they came
> > back good and I am able to view the layers with the Oracle
> MapViewer but they
> > are not showing up with MapServer. I am not getting an error
> back from
> > MapServer and I have looked for the MapServer log but I cannot
> find them.
> > Question: Where are the MapServer logs in a Windows/Apache install?
> > Another thing that I find interesting is that some of the layers
> stop> rendering at a certain scale. For example I have a layer
> that contains the
> > cities of British Columbia (from one of the Oracle layers that
> is working).
> > It has a Maximum scale of 1:5,000,000 yet at some point while
> zooming in the
> > labels disappear and don't come back again until I zoom out. Is this
> > normal?
> > Thanks for your help
> > Eric Wright
> Este e-mail foi enviado pelo webmail do curso de
> Ciência da Computação - UNIVALI
