getting extents for displaying individual states
G-Net Consulting
joelf at GNETCONSULTING.COM
Wed Sep 8 15:15:49 EDT 2004
Hello list:
I'm attempting to do the same thing, but keep hitting a hurdle,
and have yet to find a solution in the archives. Here's my code:
// get our state layer
$stLayer = $gmfMap->getLayer(1);
$stLayer->set("status", MS_ON);
// query the passed state
$qryLayer = $stLayer->queryByAttributes("STATE", $_GET["state"],
MS_MULTIPLE);
// find out how many results we found
$shpCount = $stLayer->GetNumResults();
// open the layer
$stLayer->open();
for ($i = 0; $i < $shpCount; $i++) {
// get the results we need from the layer
$result = $stLayer->getResult($i);
// get our shape info from the index
$shpData = $stLayer->getShape($result->tileindex, $result->shapeindex);
print_r($result);
// ... (do something with the result)
When I get to the getShape() function, I get an error saying "Invalid
feature id."
I know it has to be something simple. I, too, am trying to get the extents
for
a passed state to "zoom" into it. Layer #1 is my states layer.
I'm using PHP/MapScript (4.x+ versions).
TIA!
Joel
----- Original Message -----
To: <MAPSERVER-USERS at lists.umn.edu>
Sent: Monday, August 30, 2004 4:36 PM
Subject: Re: [UMN_MAPSERVER-USERS] getting extents for displaying individual
states
> On Mon, 2004-08-30 at 13:20, Bob Cook wrote:
>> I'm working with a map of the entire United States (including Alaska,
>> Hawaii, and other US territories).
>> I would like to allow users to select an individual state (or territory)
>> from a dropdown list and have the map center around that state, and zoom
>> in to it.
>> Is there any easy way of programmatically setting my map's extents
>> (without simply hard-coding extents for each state) so that it centers
>> on one state?
>> I'm using PHP/Mapscript.
> Assuming all your states are in one layer you will need to execute an
> attribute query against the layer based on the name of the state
> entered.($layer->queryByAttrbute()) The query results will give you
> access to the shape of the state you want. That shape has a bounds
> member which is a rectangle which can be use to set the extent of you
> new map.
> $minx = $shape->{bounds}->{minx};
> etc.
