internal server error 500
Speiser Ferenc speiser.ferenc at FREEMAIL.HU
Thu Sep 9 04:54:03 EDT 2004
Hi All!
I have a problem with running MapServer perfectly.
It seems to be working, but if I try to test the example below I get error message: 500 - internal server error.
All the settings seems to be fine. If I change the status from default to on, it is working but I can see only a gray rectangle. Not the contents of the shapefile, althoug the extents has to be right, because that is the original example!. :(
I found a bug report (http://www.maptools.org/bugzilla/show_bug.cgi?id=620
) about extracting shapfiles, do you think that causes my problem also? If it is, then how should I fix it?
Thx:
Ferenc Speiser
MAP
  IMAGETYPE      PNG
  EXTENT         201621.496941 -294488.285333 1425518.020722 498254.511514
  SIZE           400 300
  SHAPEPATH      "c:\data"
  IMAGECOLOR     240 240 240
  PROJECTION
    "proj=laea"
    "ellps=clrk66"
    "lat_0=45"
    "lon_0=-100"
  # Alternatively, you can specify an EPSG code.
  # "init=epsg:2163"
  END
  # Start of LAYER DEFINITIONS ---------------------------------------------
  LAYER # States polygon layer begins here
    NAME         states
    DATA         states_ugl
    STATUS       default
    TYPE         POLYGON
    PROJECTION
      "init=epsg:4326"
    END
    CLASS
      COLOR        232 232 232
      OUTLINECOLOR 32 32 32
    END
  END # States polygon layer ends here
  # End of LAYER DEFINITIONS -------------------------------
END # end of map file/object
University of Veszprém
Department of Automation
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20040909/8785a25a/attachment.html
