[UMN_MAPSERVER-USERS] How keep the Selection of the
layers in HTML
Richard Greenwood
richard.greenwood at GMAIL.COM
Thu Sep 9 17:34:00 EDT 2004
Checkout SAVEQUERY and QUERYFILE in the CGI reference. This allows you
to save a selection and eliminates the overhead of running the query
each time the map needs to be redrawn. And it does not require any
scripting!
Rich
Richard Greenwood
richard.greenwood at gmail.com
www.greenwoodmap.com
On Thu, 9 Sep 2004 09:14:54 -0400, Skweda O'Bomsawin
<sobomsawin at kassini.com> wrote:
> Pierre,
> You can keep your selection active while using mapscript as CGI, but it's a
> little bit tricky. What you have to do is to make your selection with a
> query or nquery mode, catch the unique ids of elements selected which
> Mapserver will return and insert these values into an URL with itemnquerymap
> or itemquerymap mode, or simply create a new layer and use a filter...
> Personally, I use Java and Mapscript CGI to do this and it works like a
> charm!
> Hope this can help...
> Skweda O'Bomsawin
> -----Message d'origine-----
> De : UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] De la
> part de Pierre RELLA
> Envoyé : 9 septembre 2004 03:12
> À : MAPSERVER-USERS at LISTS.UMN.EDU
> Objet : [UMN_MAPSERVER-USERS] How keep the Selection of the layers in HTML
> Hi,
> In "html" when i refresh the page, the new page lost the selection
> of the
> layers. How can i keep the previous selection? I think using PHP .If
> somebody have a script ....
> Best Regards
