MrSID mapserver vs gdal_translate
Frank Warmerdam
warmerdam at POBOX.COM
Fri Sep 10 11:10:00 EDT 2004
Simpson wrote:
> Hi,
> I find gdal_translate about three times faster than mapserver when
> processing a small area from a MrSID file. If I add a class definition to
> the layer in the map file, the results are black and white, but the image
> renders at about the same speed as gdal_translate. Is this disparity in
> time a result of bands being extracted separately?
Drew,
Yes, the performance issue is related to MapServer reading each band
seperately.
What I really need to do is modify mapdrawgdal.c to use the "several bands
at once" interface to GDAL (relatively new in GDAL) to accelerate performance.
But doing this will mean a non-trivial restructuring of the code so I have
put it off.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
