symbology question
Titus von der Malsburg malsburg at CL.UNI-HEIDELBERG.DE
Fri Sep 10 20:33:11 EDT 2004
On Fri, Sep 10, 2004 at 03:11:43PM -0600, Richard Greenwood wrote:
> Bart's SLD suggestion below is an excellent approach if you are
> working in a WMS environment.
> If you are working with mapscript, it is easy to alter the styles.
> If you are working with the CGI interface, you can over-ride map file
> parameters with CGI variables like this:
>    MAP_layerName_className_SYMBOL=xyz
Correct me if I'm wrong but I think SLD is not only usable in a WMS
environment.  Mapscripts that apply user supplied or generated SLDs are
imaginable as well.  And this wouldn't be the worst choice.
        Titus
