postGIS problems
Tim Tsai ttsai at POBOX.COM
Tue Sep 14 05:07:13 EDT 2004
I installed mapserver/postgis a few days ago but I can't seem to get
a simple example working.  Is somebody willing to send me an example
postGIS map file as well as an SQL dump of their test database?
I just need a working demo - even if all it does is draw one line on
the screen.
This is the mapfile I've used so far.  I believe the extent is
right judging from the SQL result below.  All I get is just a gray
background on the PNG - no line segments at all.  I've also tried
TYPE LINES and same problem.
I have verified that database connection is successful and queries
were made.
Thanks,
Tim
-- extent query --
ogc=# select extent(centerline) from road_segments;
        extent
 BOX3D(0 0 0,84 48 0)
(1 row)
-- mapserver.log --
Tue Sep 14 03:55:16 2004,50497,69.244.27.248,DEMO,3,-0.140300 -4.060000 84.140300 52.060000,-1.000000 -1.000000,DEMO ,normal execution
-- mapfile --
MAP
    NAME DEMO
    SIZE 600 400
    IMAGETYPE PNG
    IMAGECOLOR 240 240 240
    EXTENT 0 0 84 48
    WEB
        LOG /tmp/mapserver.log
    END
    DEBUG ON
    LAYER
        CONNECTIONTYPE postgis
        NAME "DEMO"
        # Connect to a remote spatial database
        CONNECTION "user=user dbname=db host=127.0.0.1"
        DATA "centerline from road_segments"
        TYPE POLYGON
        STATUS DEFAULT
    END
END
