mygis segfault
Peter Drake pdrake at GMAIL.COM
Tue Sep 14 09:45:02 EDT 2004
I am getting a segfault whenever I try to query a MySQL layer.
mapserver will display these layers fine but queries end up in a
segfault.  I don't know enough about programming to find a solution to find
the problem on my own.  Can someone point me in the right direction?
Here is the command I am executing through gdb:
./mapserv QUERY_STRING="map=/home/virtual/"
The results returned (it fills out the query header template but then
segfaults before filling out the query template):
Content-type: text/html
Program received signal SIGSEGV, Segmentation fault.
0xb7115d33 in strlen () from /lib/tls/
The backtrace from gdb:
#0  0xb7115d33 in strlen () from /lib/tls/
#1  0xb7115a75 in strdup () from /lib/tls/
#2  0x08079723 in msMYGISLayerOpen (layer=0x8120874) at mapmygis.c:318
#3  0x0807bca6 in msLayerOpen (layer=0x8120874) at maplayer.c:150
#4  0x080595dc in msReturnQuery (msObj=0x8105e08,
 pszMimeType=0x8127938 "text/html", papszBuffer=0x0) at maptemplate.c:2730
#5  0x0805313f in msReturnTemplateQuery (msObj=0x8105e08,
 pszMimeType=0x8127938 "text/html", papszBuffer=0x0) at maptemplate.c:212
#6  0x0805074b in main (argc=-1227358200, argv=0xbfffe554) at mapserv.c:1338
