wms raster rquest crash!
Ed McNierney ed at TOPOZONE.COM
Wed Sep 15 14:18:59 EDT 2004
Haiayan  -
Well that's some new information!  You didn't mention that this image
was working in MapServer before you had trouble.
Are you certainly that you rebuilt MapServer with a current and complete
set of supporting libraries, particularly the current versions of
libtiff and libgeotiff?
        - Ed
Ed McNierney
President and Chief Mapmaker
TopoZone.com / Maps a la carte, Inc.
73 Princeton Street, Suite 305
North Chelmsford, MA  01863
ed at topozone.com
(978) 251-4242
-----Original Message-----
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On
Behalf Of Haiyan Liu
Sent: Wednesday, September 15, 2004 2:00 PM
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: Re: [UMN_MAPSERVER-USERS] wms raster rquest crash!
Hi Frank and Ed, thank you for your responses.
We are currently using GDAL 1.1.9.0, released 2003/06/27.
Up till I posted this problem, our Admin has helped us try all the
latest gdal versions in no vail. We do have successfully set up the the
same wms on the same box and another box before. But since we recompiled
everying of mapserver from the latest releases, we encountered the
current problem. And now even we tried switching back to some earlier
releases, it was still not working(well, it really should).
Not sure whether or not data could be causing this the problem because
we used the same data before. Here is the file anyways.
        www.firstbasesolutions.com/tmp_download
Sincerely,
Haiyan
On Wed, 2004-09-15 at 10:15, Frank Warmerdam wrote:
> Haiyan Liu wrote:
>   >>From this list, we noticed some postings on this problem. As some
> folks
> > suggested that SegFault problem could be traced to mapserver's
> > shp2img, so we tried shp2img and did get that segfault crash. When
> > we tried using gdb to 'debug' the shp2img util with the same
> > mapfile, we found it crashed on tif_read, here is the message before
> > it died,
> > (gdb) run -m /var/www/html/zoom2it_mapserver/map_file/test_wms.map
> > Starting program: /root/build/mapserver-4.0.1/shp2img
> > -m/var/www/html/zoom2it_mapserver/map_file/test_wms.map
> > (no debugging symbols found)...
> > (no debugging symbols found)...[Thread debugging using
> > libthread_dbenabled] [New Thread -1084655424 (LWP 5180)] Program
> > received signal SIGSEGV, Segmentation fault.
> > [Switching to Thread -1084655424 (LWP 5180)]0x00a036ad in
> > TIFFFillStrip (tif=0x8863628, strip=1) at tif_read.c:252252
> > bytecount = td->td_stripbytecount[strip];
> > I hope i have explained my problem clearly. Any help/hint will be
> > greatly appreciated! By the way, almost all mapserver versions above
> > 4.0.1 have been triedwith the same configs as below and failed
exactly the same way.
> Haiyan,
> When reporting crashes within gdb it is also helpful to do a "where"
> command so we can see the whole call stack.
> This seems like it might be a bug in GDAL.  I would encourage you to
> report it in the MapServer Bugzilla and ensure it is assigned to me.
> You will need to provide a dataset (ideally a smallish raster file
> that also demonstrates the problem). Also, ensure you provide details
> on the version of GDAL you are using.
> Best regards,
First Base Solutions Inc.
145 Renfrew Drive
Suite 160
Markham ON  L3R 9R6
T. 905.477.3600
F. 905.477.3882
