WMS GetFeatureInfo XML Format error
Yewondwossen Assefa
assefa at DMSOLUTIONS.CA
Thu Sep 16 10:46:39 EDT 2004
The GetFeatureInfo takes as argument INFO_FORMAT instead of FORMAT. So
you should specify INFO_FORMAT=text/xml. You must also make sure that
the layer on which you do the request has a valid template attched to it
(xml document in your case).
Later,
Bastarrika Izagirre wrote:
> I have put Dump True but the error is still the same. ¿Any other suggestion?
> Thanks
> Aitor
> >From: Paul Spencer <pagameba at MAGMA.CA>
> >Reply-To: Paul Spencer <pagameba at MAGMA.CA>
> >To: MAPSERVER-USERS at LISTS.UMN.EDU
> >Subject: Re: [UMN_MAPSERVER-USERS] WMS GetFeatureInfo XML Format error
> >Date: Thu, 16 Sep 2004 07:31:54 -0500
> >you must add DUMP TRUE to your layer if you want it to return XML
> >results.
> >>Hi all:
> >>I have problems with GetFeatureInfo request. I want the response in
> >>XML format and i receive it in text/plain format.
> >>I have added in my .map file the WMS_FEATURE_INFO_MIME_TYPE
> >>'text/xml' parameter so GetCapabilities response is:
> >><GetFeatureInfo>
> >> <Format>text/plain</Format>
> >> <Format>text/xml</Format>
> >> <Format>application/vnd.ogc.gml</Format>
> >> <DCPType>
> >> <HTTP>
> >> <Get><OnlineResource
> >>xmlns:xlink="http://www.w3.org/1999/xlink"
> >>xlink:href="D:/mapserver_aplic/templ.html?"/></Get>
> >> <Post><OnlineResource
> >>xlink:href="D:/mapserver_aplic/templ.html?"/></Post>
> >> </HTTP>
> >> </DCPType>
> >> <! /GetFeatureInfo>
> >>when I make the GetFeatureInfo request with the option
> >>FORMAT=text/xml
> >>i get the error
> >><?xml version='1.0' encoding="ISO-8859-1" standalone="no" ?>
> >><!DOCTYPE ServiceExceptionReport SYSTEM
> >>"http://schemas.opengis.net/wms/1.1.1/WMS_exception_1_1_1.dtd">
> >><ServiceExceptionReport version="1.1.0">
> >><ServiceException code="InvalidFormat">
> >>msWMSLoadGetMapParams(): Image handling error. Unsupported output
> >>format (text/xml).
> >></ServiceException>
> >></ServiceExceptionReport>
> >>If I don't specify the Format parameter the request is valid in
> >>plain
> >>text format.
> >>Could someone help me?
> >>Thanks,
> >>aitor
> >>Consigue aquí las mejores y mas recientes ofertas de trabajo en
> >>América Latina y USA: Haz clic aquí...
> >><http://g.msn.com/8HMAES/2743??PS=47575>
> Las mejores tiendas, los precios mas bajos, entregas en todo el mundo,
> YupiMSN Compras: Haz clic aquí... <http://g.msn.com/8HMAES/2746??PS=47575>
Assefa Yewondwossen
Software Analyst
Email: assefa at dmsolutions.ca
http://www.dmsolutions.ca/
Phone: (613) 565-5056 (ext 14)
Fax: (613) 565-0925
