Finally compiled my MapServer 4.2.3, but got error when using it as cgi app.
Jingyu Bai baijingyu at HOTMAIL.COM
Sat Sep 18 12:13:59 EDT 2004
Hi, thanks for the help from this forum and after reading most useful posts
in forum I can finally compiled the map server in MT option which is using
LIBCMT.LIB in VC 6++ under XP.  The mapserv.exe file size is much bigger
than the mapserver distribution version (mine is 369k). I used DOS command
line >mapserv -v and got:
D:\Projects\mapserver-4.2.3>mapserv -v
MapServer version 4.2.3 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
SUPPORTS=PROJ SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT
SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT INPUT=JPEG INPUT=ORACLESPATIAL
INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
This means I at least compiled the Map server but when I put this exe file
in apache cgi-bin folder and trying to test it from web using
http://localhost/cgi-bin/mapserv.exe?map=D:\Projects\mapserver-4.2.0-
distribution\httpdoc\data\example1-1.map&mode=map
I got a Microsoft popup fatal error window and ask me if I want to send
"mapserv.exe has encountered a problem and needs to close.  We are sorry
for the inconvenience." ...
If I only use
http://localhost/cgi-bin/mapserv.exe without paramters, I wouldn't get
microsoft error window instead I got a msg in my IE browser saying
"No query information to decode. QUERY_STRING is set, but empty. "
If I use Map Server binary distribution mapserv.exe and I wouldn't get
above error.
I got Map Server compiled by reading all helpful post here but why I still
get the error when trying to use it as a cgi script ???!!!  Is this related
to the option I used to compile GDAL and mapserver? if so could somebody
send me your working windows VC version of GDAL namke.opt file and
mapserver makefile.vc to me? Please help me.  Thanks
