GetFeatureInfo on ESRI binary grid
Frans Knibbe
frans at GEODAN.NL
Mon Sep 20 10:22:39 EDT 2004
Jim wrote:
>For raster layers you need the file extension too.
>DATA "E:\data\elevation.tif" or whatever it is.
Are you sure? An ArcInfo grid is not a single file, but a directory
containing several files. I have just tried using a filename
(E:\data\elevation\w001001.adf), but I got the same results: GetMap
works, but GetFeatureInfo doesn't. If I should use a filename in stead
of the directoryname, which of the files should I use?
>-jim
>Jim Burnett
>Visual Basic GIS Project Leader
>http://www.visualbasicgis.com/
>http://www.gisforums.com/
>----- Original Message -----
>From: "Frans Knibbe" <frans at GEODAN.NL>
>To: <MAPSERVER-USERS at LISTS.UMN.EDU>
>Sent: Monday, September 20, 2004 9:11 AM
>Subject: [UMN_MAPSERVER-USERS] GetFeatureInfo on ESRI binary grid
>>Hello people,
>>I am using mapserver 4.2.3 with GDAL and I have a problem. Maybe someone
>>can help? I am trying to get the GetFeatureInfo request to work on an
>>ArcInfo grid. The grid displays well. Here is a part of the map file in
>>its current shape:
>> LAYER
>> NAME "elevation"
>> DATA "E:\data\elevation"
>> TYPE RASTER
>> END
>> LAYER
>> STATUS ON
>> NAME "elevation_query"
>> TYPE QUERY
>> DUMP TRUE
>> TEMPLATE template.htm
>> END
>>As you can see, I have defined two layers, one for display and one for
>>query. This is because I could not get the "type raster" layer to become
>>queryable. When I request the capabilities, the second layer is reported
>>to be queryable, but the first not. However, a getFeatureInfo request
>>results in the following error:
>><ServiceException>
>> msSHPOpenFile(): Unable to access file. (E:\data\elevation)
>> </ServiceException>
>>Is there something I am obviously doing wrong? Is there another raster
>>format that might work better?
>>Thanks in advance,
>>Frans
