error message
John Bolster
jb at NUCOMP.COM
Tue Sep 21 13:49:12 EDT 2004
Yet again, thank you.
I'll do multiple tileindexes. Then when I use shptree I assume I run it once
for each of the different tileindex shp files, or is there a way to
incorporate the larger-than-county layers into the spatial index?
John
> -----Original Message-----
> From: Stephen Woodbridge [mailto:woodbri at swoodbridge.com]
> Sent: Tuesday, September 21, 2004 1:26 PM
> To: John Bolster
> Cc: MAPSERVER-USERS at LISTS.UMN.EDU
> Subject: Re: [UMN_MAPSERVER-USERS] error message
> John,
> The typical way wo do this is to create separate tileindexes for each
> layer. So you would have a tileindex for roads, another for water lines
> and one for water polygons, etc. For tiger data this would me you would
> create approximately 10+- tileindexes. Then in the mapfile specify the
> TILEINDEX and leave the DATA statement out.
> I would recommend doing the above ... but for those that like to inflict
> pain on themselves ...
> There is an option on tile4ms like --directory-only that leaves off the
> final file name, it unfortunately does not combine the multiple
> directory entries into a single entry which renders it useless, unless
> you want to write a script to do that your self. Assuming you wrote the
> script yourself, you could then have ONE tileindex that would reference
> the extents of the county regardless of the data layers in it, and you
> could then set up your mapfile layers like:
> LAYER
> NAME "streets"
> TILEINDEX "my-county-tiles"
> DATA "roads"
> END
> This would cause path in the TILEINDEX to be concatenated with the DATA
> name to get the path to the data files. In this configuration only the
> <tile-path>/roads.shp will be looked at.
> I think I would recommend using the multiple indexes as it will be
> easier to build and maintain.
> -Steve
> John Bolster wrote:
> > Thanks Steve,
> > I have various layers of tiger/line data organized into one
> directory per
> > county and I've been trying to make one tileindex for the whole
> thing. Based
> > on what you're saying, do I need to run tile4ms separately on
> each different
> > type of layer, so that I end up with a tileindex for the
> counties, one for
> > the roads, one for the places, etc.?
> > John
> >>Sent: Tuesday, September 21, 2004 10:22 AM
> >>To: John Bolster
> >>John,
> >>The way tileindexes work is the you group a bunch of files into a
> >>virtual layer. All the files must have the same dbf columns defined in
> >>them and defined in the same order. This is because mapserver reads the
> >>attribute layout of the first file it opens and uses that as the
> >>template for all files in the virtual layer.
> >>So if the first file had attribute columns [A, B, C] and some other file
> >>had [D, E] or [B, C, A] or whatever it would cause problems for
> >>mapserver. If you ask mapserver to CLASS on C, it translates that to
> >>column 3 and then tries to read column 3 from the [D, E] and gets an
> >>error, or gets column A from [B, C, A] file, etc. This was causing a lot
> >>of problems for people that did not understand the inner workings of
> >>mapserver, so this check was added to prevent people from doing bad
> >>things and not knowing about it.
> >>Some version of dbfdump will display the column definitions of you
> >>files. You either have some that have a different definition like a
> >>different version of the file, or you are picking up some files that are
> >>not compatible with the first file you add to the index.
> >>Hope this helps,
> >> -Steve W.
> >>John Bolster wrote:
> >>>Hello,
> >>>Does anyone know what "DBF fields do not match" means in the
> output from
> >>>tile4ms?
> >>>Do they not match to one another, or to a certain way they're
> >>meant to be,
> >>>or to the shapefile, or what? The files were created with
> >>tgr2shp so I don't
> >>>see why they should be bad. And what would I do about this--I
> >>can't imagine
> >>>I'm the only person to whom this has happened.
> >>>Thanks for your help,
> >>>John Bolster
