PHP ms_newLayerObj vs SWIG layerObj
Ryan, Adam
ARyan at CO.LINN.OR.US
Thu Sep 23 16:24:35 EDT 2004
Am I missing something simple?
In PHP I'm able to take a layer from one map and add it to another map using
ms_newLayerObj($map_object,$layer_object_from_another_map);
Is there a way to do this with SWIG mapscript. The layerObj method takes
only one argument - the map. Is there a clone() for layers or something
like that?
Adam
-----Original Message-----
Sent: Thursday, September 23, 2004 12:26 PM
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: Re: [UMN_MAPSERVER-USERS] Editing shapefiles through mapserver
The info your looking for is most likely in the old archives. You can search
it with either the built-in search engine or google.
Lowell
The following message was sent by David Horowitz <mapuser at VERYSPEEDY.NET> on
Thu, 23 Sep 2004 15:19:23 -0400.
> Hello,
> I am wondering if there are any tutorials or reference documents
> available that describe how to allow users to add points to shapefiles
> dynamically through mapserver.
> As an example, the mapserver users map (located at:
> http://www.moximedia.com:8080/imf-ows/imf.jsp?site=ms_users) is almost
> exactly what I would like to accomplish, although in a different
> context.
> Any help would be very appreciated, I've looked through the wiki
> without any luck. Am I missing something? Thank you for your help.
